Bronze
Redistributing Routes based on TAGS
I have a bunch of static routes I am RD'ing into OSPF and marking with a tag of 123
I want to then RD these routes ( only routes marked with tag 123) into EIGRP.
Can I achieve this with a route-map and a command in my EIGRP statement?
I'll start with
route-map RD-123 permit 10
match tag 123
Do I then need to deny everything else with another sequence number?
Can I achieve what I am trying to do above?
1 ACCEPTED SOLUTION
Hi, yes, you can do that.If
If you redistribute your static routes to OSFP tagging with 123 on one router, you can then configure on another router:
router eigrp x
redistribute ospf y route-map RD-123
uisng your route-map suggested in your original post. You deon't need any deny entry in the route-map.
You can even use
redistribute ospf y match external 2 route-map RD-123
to be safer.
Best regards,
Milan
Matching the tag would
Matching the tag would probably work. I don't think I've done it that way but it should be fine.
Or, you could use a route-map with permit on a match on OSPF type-2 routes and a deny on OSPF internal.
router eigrp x
You can even use
to be safer.
Best regards,
Milan
44
