11-19-2008 12:21 AM - edited 03-04-2019 12:24 AM
Im matching some Prefixes - Acccesslist and redistributing them in to bgp via a route map.
But for all my prefixes in static its saying Redistributing via bgp, when i chk by sho ip route x.x.x.x
y so ?
Solved! Go to Solution.
11-19-2008 03:18 AM
Hello Rajeev,
if you compare the output of show ip route for two prefixes, one matching the route and one not matching you will see a difference:
the matching one has an additional line that says
advertised by ...
see the following example:
RT-RM-TLD066-RG-EST-2#sh ip route 10.34.16.48
Routing entry for 10.34.16.48/28
Known via "static", distance 1, metric 0 (connected)
Redistributing via isis
>>> Advertised by isis metric-type internal level-1-2 route-map red_stat
Routing Descriptor Blocks:
* directly connected, via Tunnel59
Route metric is 0, traffic share count is
that line is missing for a prefix not matching the route-map
the line redistributing via BGP just tells there is a red static inside router bgp.
Hope to help
Giuseppe
11-19-2008 12:32 AM
If you are redistributing static routes into BGP, it is normal to see Redistributing via bgp when you do a sh ip route for that prefix
Narayan
11-19-2008 01:20 AM
thanx for the reply narayan .
Im saying the static routes which r not matching the route map ( access-list) will not be redistributed in to bgp.
But thos routes also saying redistributing via bgp. can any one explain pls
11-19-2008 02:21 AM
Rajeev
Perhaps if you posted the config we would be able to help you further.
Jon
11-19-2008 03:18 AM
thanx for reply jon,
router bgp xxx
redistribute static route-map STATIC-BGP
route-map STATIC-BGP permit 10
match ip address STATIC-BGP
set as-path prepend xxx xxx xxx
ip access-list standard STATIC-BGP
permit 10.1.1.0 0.0.0.255
ip route 20.1.1.0 255.255.255.0 10.1.1.3 -------------> Static route not matching the acl
ip route 10.1.1.0 255.255.255.0 10.1.1.3 -------------> Static route matching the acl
sh ip route 10.1.1.0
Routing entry for 10.1.1.0/24
Redistributing via bgp xxxx --- > saying Redistributing via bgp for match ,this is perfect( happening through bgp)
Advertised by bgp xxx route-map STATIC-BGP
* 10.1.1.3
Route metric is 0, traffic share count is 1
sh ip route 20.1.1.0
Routing entry for 20.1.1.0/24
Redistributing via bgp xxxx --- > saying Redistributing via bgp ( even when it's not)
* 10.1.1.3
that it. i hope u got it.
11-19-2008 03:18 AM
Hello Rajeev,
advertised by ...
Hope to help
Giuseppe
11-19-2008 03:37 AM
Dear Giuseppe
I got it.Thanks a lot.Rated too ;)
11-19-2008 03:44 AM
I see "Advertised by bgp xxx route-map STATIC-BGP" in both routes or isn't that so?
In any case, I would do a "sh ip bgp
When having issues with redistribution, removing and re-applying the redistribution command or/and route-map might help.
Kind Regards,
M.
11-19-2008 03:45 AM
Giuseppe
I may be mistaken but it looks to me like both "sh ip route" statements have an "advertised by .." statement in them.
Jon
11-19-2008 04:18 AM
no Giuseppe ,
U were correct , i did some editing in the outout as i could not find a non-matching static as it's production - which i really missed :P
Tlater i checked the diference and found ur statement exactly matches .. thanx a lot again.
