Redistributing via bgp
Im matching some Prefixes - Acccesslist and redistributing them in to bgp via a route map.
But for all my prefixes in static its saying Redistributing via bgp, when i chk by sho ip route x.x.x.x
y so ?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Redistributing via bgp
Hello Rajeev,
if you compare the output of show ip route for two prefixes, one matching the route and one not matching you will see a difference:
the matching one has an additional line that says
advertised by ...
see the following example:
RT-RM-TLD066-RG-EST-2#sh ip route 10.34.16.48
Routing entry for 10.34.16.48/28
Known via "static", distance 1, metric 0 (connected)
Redistributing via isis
>>> Advertised by isis metric-type internal level-1-2 route-map red_stat
Routing Descriptor Blocks:
* directly connected, via Tunnel59
Route metric is 0, traffic share count is
that line is missing for a prefix not matching the route-map
the line redistributing via BGP just tells there is a red static inside router bgp.
Hope to help
Giuseppe
If you are redistributing static routes into BGP, it is normal to see Redistributing via bgp when you do a sh ip route for that prefix
Narayan
thanx for the reply narayan .
Im saying the static routes which r not matching the route map ( access-list) will not be redistributed in to bgp.
But thos routes also saying redistributing via bgp. can any one explain pls
Hall of Fame Super Blue
Rajeev
Perhaps if you posted the config we would be able to help you further.
Jon
thanx for reply jon,
router bgp xxx
redistribute static route-map STATIC-BGP
route-map STATIC-BGP permit 10
match ip address STATIC-BGP
set as-path prepend xxx xxx xxx
ip access-list standard STATIC-BGP
permit 10.1.1.0 0.0.0.255
ip route 20.1.1.0 255.255.255.0 10.1.1.3 -------------> Static route not matching the acl
ip route 10.1.1.0 255.255.255.0 10.1.1.3 -------------> Static route matching the acl
sh ip route 10.1.1.0
Routing entry for 10.1.1.0/24
Redistributing via bgp xxxx --- > saying Redistributing via bgp for match ,this is perfect( happening through bgp)
Advertised by bgp xxx route-map STATIC-BGP
* 10.1.1.3
Route metric is 0, traffic share count is 1
sh ip route 20.1.1.0
Routing entry for 20.1.1.0/24
Redistributing via bgp xxxx --- > saying Redistributing via bgp ( even when it's not)
* 10.1.1.3
that it. i hope u got it.
Hello Rajeev,
advertised by ...
Hope to help
Giuseppe
Dear Giuseppe
I got it.Thanks a lot.Rated too ;)
I see "Advertised by bgp xxx route-map STATIC-BGP" in both routes or isn't that so?
In any case, I would do a "sh ip bgp ".
When having issues with redistribution, removing and re-applying the redistribution command or/and route-map might help.
Kind Regards,
M.
Giuseppe
I may be mistaken but it looks to me like both "sh ip route" statements have an "advertised by .." statement in them.
Jon
no Giuseppe ,
U were correct , i did some editing in the outout as i could not find a non-matching static as it's production - which i really missed :P
Tlater i checked the diference and found ur statement exactly matches .. thanx a lot again.
431
