Redistribution BGP and EIGRP
pramod
Dear All,
Please refer the above diagram. I would like to do mutual redistribution on RTR1 and RTR2 (EIGRP to BGP and BGP to EIGRP and vice versa)
How to do filter to avoid loops.
The primary traffic should flow through dark fiber. If dark fiber fails traffic has to flow through ISP.
Express your best fixes.
2 Accepted Solutions
Hello pramod, Actually I would like to correct myself firstly by saying that, in fact you will not need to filter between eigrp and bgp - oversight on my part. Reason is because both sets of protocols have the AD characteristic change in the type of routes.
If you are running iBGP and by your diagram it looks that way, the routes will have an AD of 200. This is worse than EIGRP D routes metric of 90 and EIGRP D EX routes metric of 170.
This means that EIGRP will always be preferred - i.e. dark fiber links. ONLY if both dark fiber links failed for whatever reason, then iBGP learned routes with metric of 200 will enter the RIB and be used.
eBGP also has its own loop prevention mechanism where it will not use / accept routes, learnt that have the same AS in AS_PATH's attribute. This could cause you a problem in learning the route's back from ebgp.
But iBGP should be OK.
hth
Bilal
CCIE #45032
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
No you don't need to change the AD. The router will automatically prefer any internal routes over eBGP regardless of the AD. If you control BGP on both sides I would move from iBGP to eBGP and put them in different AS numbers.
14 Replies 14
michael o'nan
Level 4
Level 4
Since your routers use BGP you will automatically experience traffic preferring dark fiber as it is seen as an internal route.
You can use something like distribute list and apply it to your routing protocol.
Yes true,
I was actually looking for route-map with filter-list for EIGRP to BGP and BGP to EIGRP.
That will work as well. Are you asking for a sample config?
yes michael, i am looking for sample route-map config's to put and test which match the above scenario.
I may recommend setting TAG's on the routes in a way where you can easily identify where routes are originating from. Denying via matching the TAG set on the routes will make it very easy for you to filter and avoid loops.
If you use EIGRP and all routes are internal routes with AD of 90 this is fine. Dark fiber will be preferred - you might opt to change the EIGRP AD for "D EX" type routes to lower than BGP - this could also stop routing loops. But like i mentioned if i was in this scenario i would use tagging
eg.
tag eigrp routes via R1 - deny those routes on R2 coming in via BGP
tag eigrp routes via R2 - deny those routes on R1 coming in via BGP
Likewise with BGP
In another case you could summarise at BGP outbound but have the more specific routes via EIGRP and infact this might be the cleaner option rather than using route-maps and filtering etc.... In which case you wouldn't need higher BGP AD or Lower EIGRP internal AD either.
hth
Bilal
CCIE #45032
Hi Bilal,
This is how i done on RTR1 and RTR2. Is it correct?
route-map EIGRP-TO-BGP deny 5
 match metric 250
route-map EIGRP-TO-BGP permit 10
 match ip address 11
 set metric 250
route-map BGP-TO-EIGRP deny 5
 match tag 5
route-map BGP-TO-EIGRP permit 10
 set metric 400 20 255 1 1500
 set tag 5
router bgp 65XXX
 bgp router-id X.X.X.X
 bgp log-neighbor-changes
 bgp redistribute-internal
redistribute eigrp 1 route-map EIGRP-TO-BGP
router eigrp 1
redistribute bgp 65XXX route-map BGP-TO-EIGRP
hth
Bilal
CCIE #45032
Ok, so for eBGP scenarios, i believe need to change the AD as it's 20 by default?
Yes, if the soul purpose of the bgp is for backup then yes, caveat is that RTR1 and RTR2 must be in their own AS - for the reason i stated, bgp's loop prevention mechanism.
hth
Bilal
CCIE #45032
Thanks Bilal and Michael.
Hi Michael I disagree here. if you do this then eBGP routes will be used with AD of 20, it will achieve the undesired result of routing primarily via the bgp circuit. I believe changing AD on ebgp routes will be necessary. I do agree that AS should be split. If ibgp is used it then it will be fine.
Disagree all you like but I have Parmod's exact topology setup in lab. The following config and routing table proves you don't have to change AD on eBGP for the route to be preferred over ANY internal routing protocol.
R1
R1#sh run | s router
router eigrp 1
 redistribute bgp 1
 passive-interface FastEthernet0/0
 network 1.1.1.0 0.0.0.255
 network 11.11.11.0 0.0.0.255
 network 33.33.33.0 0.0.0.255
 no auto-summary
router bgp 1
 no synchronization
 network 1.1.1.0 mask 255.255.255.0
 network 11.11.11.0 mask 255.255.255.0
 neighbor 11.11.11.12 remote-as 2
 no auto-summary
 R2
R2(config-router)#do sh run | s router
router eigrp 1
 redistribute bgp 2
 network 2.2.2.0 0.0.0.255
 network 23.23.23.0 0.0.0.255
 no auto-summary
router bgp 2
 no synchronization
 network 2.2.2.0 mask 255.255.255.0
 neighbor 11.11.11.11 remote-as 1
 no auto-summary
 R1
C       1.1.1.0 is directly connected, Loopback0
     2.0.0.0/24 is subnetted, 1 subnets
D       2.2.2.0 [90/161280] via 33.33.33.33, 00:01:02, FastEthernet1/0
     33.0.0.0/24 is subnetted, 1 subnets
C       33.33.33.0 is directly connected, FastEthernet1/0
D       3.3.3.0 [90/156160] via 33.33.33.33, 00:16:44, FastEthernet1/0
     4.0.0.0/24 is subnetted, 1 subnets
D       4.4.4.0 [90/158720] via 33.33.33.33, 00:16:44, FastEthernet1/0
     23.0.0.0/24 is subnetted, 1 subnets
D       23.23.23.0 [90/33280] via 33.33.33.33, 00:20:14, FastEthernet1/0
     43.0.0.0/24 is subnetted, 1 subnets
D       43.43.43.0 [90/30720] via 33.33.33.33, 00:16:45, FastEthernet1/0
     11.0.0.0/24 is subnetted, 1 subnets
C       11.11.11.0 is directly connected, FastEthernet0/0
R2
D       1.1.1.0 [90/161280] via 23.23.23.42, 00:01:34, FastEthernet1/0
C       2.2.2.0 is directly connected, Loopback0
D       33.33.33.0 [90/33280] via 23.23.23.42, 00:01:34, FastEthernet1/0
D       3.3.3.0 [90/158720] via 23.23.23.42, 00:01:34, FastEthernet1/0
D       4.4.4.0 [90/156160] via 23.23.23.42, 00:01:36, FastEthernet1/0
C       23.23.23.0 is directly connected, FastEthernet1/0
     22.0.0.0/24 is subnetted, 1 subnets
C       22.22.22.0 is directly connected, Loopback2
D       43.43.43.0 [90/30720] via 23.23.23.42, 00:01:37, FastEthernet1/0
If I add passive interface between R2 and R4 then I learn all routes via BGP from R1 (which also tests failover for the fiber link).
R2
B       1.1.1.0 [20/0] via 11.11.11.11, 00:00:04
B       3.3.3.0 [20/156160] via 11.11.11.11, 00:00:04
B       4.4.4.0 [20/158720] via 11.11.11.11, 00:00:04
B       43.43.43.0 [20/30720] via 11.11.11.11, 00:00:06
Here's EIGRP config for R3 and R4 as well:
R3#sh run | s router
router eigrp 1
 network 0.0.0.0
 no auto-summary
R4#sh run | s router
router eigrp 1
 network 0.0.0.0
 no auto-summary
