Community Member
Redistribution (BGP and OSPF)
Hi I am trying to setup vrf's but I need to get my network to function properly first, so I have 4 routers and I am running bgp between R2&R3, OSPF between R1&R2 and R3&R4. Router R3 and R4 can ping all the routers on my network but R4 and R1 can only ping their directly connected routers. I have redistributed OSPF into BGP and vice versa on R4&R3 as below.
R1--R2--R3--R4
R2
router ospf 1
log-adjacency-changes
redistribute bgp 100 metric 2 subnets
network 4.4.4.4 0.0.0.0 area 0
network 165.148.122.0 0.0.0.255 area 0
router bgp 100
no synchronization
bgp log-neighbor-changes
network 4.4.4.4 mask 255.255.255.255
network 165.148.120.0 mask 255.255.255.252
redistribute ospf 1 metric 2
neighbor 165.148.120.1 remote-as 100
no auto-summary
R3
router ospf 1
network 1.1.1.1 0.0.0.0 area 0
network 165.148.121.0 0.0.0.3 area 0
router bgp 100
no synchronization
network 1.1.1.1 mask 255.255.255.255
neighbor 165.148.120.2 remote-as 100
no auto-summary
What must I do for router 1&4 to be able to ping all other routers. Is it good practice for me to advertise all other networks in OSPF for router R2&R3?
Re: Redistribution (BGP and OSPF)
Could you please post the output of < sh ip bgp and sh ip route from R2 and R3
Narayan
Hall of Fame Super Silver
Hello Lawrence,
to correctly deploy an MPLS network you should use a common IGP (OSPF in your case) on all the backbone routers.
then you can build a full mesh of iBGP sessions using loopbacks that are advertised in OSPF.
I would use for this the same loopbacks that are used by LDP to exchange messages.
the iBGP sessions then need to be of MP-BGP
router bgp 100
no bgp default ipv4-unicast
address-family ipv4 unicast
neigh x.x.x.x activate
address-family vpnv4
neigh x.x.x.x send-community extended
Edit:
if you want to setup an inter-as scenario you need to put two routers in AS 100 and two routers in AS 200 but for each subset of routers you should follow the guidelines described above
Hope to help
Giuseppe
Community Member
R2
sh ip route
1.0.0.0/32 is subnetted, 1 subnets
O 1.1.1.1 [110/2] via 165.148.120.1, 00:58:28, ATM3/0.100
155.239.0.0/24 is subnetted, 1 subnets
C 155.239.247.0 is directly connected, FastEthernet0/2
155.1.0.0/24 is subnetted, 1 subnets
C 155.1.1.0 is directly connected, GigabitEthernet0/3
4.0.0.0/32 is subnetted, 1 subnets
C 4.4.4.4 is directly connected, Loopback0
C 192.11.1.0/24 is directly connected, GigabitEthernet0/1
165.148.0.0/30 is subnetted, 1 subnets
C 165.148.120.0 is directly connected, ATM3/0.100
R3
sh ip route
C 1.1.1.1 is directly connected, Loopback0
C 155.239.247.0 is directly connected, GigabitEthernet0/3
C 155.1.1.0 is directly connected, GigabitEthernet0/2
3.0.0.0/32 is subnetted, 1 subnets
B 3.3.3.3 [20/0] via 165.148.121.2, 00:17:01
O 4.4.4.4 [110/2] via 165.148.120.2, 01:01:53, ATM1/0.100
C 192.5.1.0/24 is directly connected, GigabitEthernet0/1
165.148.0.0/30 is subnetted, 2 subnets
C 165.148.121.0 is directly connected, Serial6/0
C 165.148.120.0 is directly connected, ATM1/0.100
the problem here is once I apply the ip vrf for command on th interface on the PE's, the CE's drops immediately..
Just an FYI, you cannot redistribute BGP into any IGP without the BGP command :-
bgp redistribute-internal
You will need to add this to your config on router 2 under router bgp 100, or if you go with the above example, it will go under address-family ipv4.
Community Member
I tried all of the above configs but i still can't get it right.
please confirm this for me, to run mpls do I need to have a P router, and PE's. I've configured only these two commands mpls ip, mpls label protocol ldp between the two routers (R2&R3) to create an mpls cloud so that i can configure my vrf's on the PE and CE.
Do I need to to have mpls configurations on the P router before I can generate traffic from one end to another making use of vrf?
Lawrence,
It should be fine to have "mpls ip" configured only between r2 and r3 if those are your PEs. You do not necessarily need P routers to get MPLS VPN working. Directly connected PEs will do just fine.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Lawrence
Have a look on the attached configs i had used to simulate when learning about MPLS .. There are no P routers in them
Hope it helps
Narayan
Community Member
I will be trying the configs you gave me in three hours, I will provide feedback. I can't access my lab at this stage I don't know what happened. will be checking in the morning(in 4 hours from now).
Community Member
I have tried your configs, my problem now is: I cannot activate the neighbor on address-family vpnv4 here is an error message "Specify remote-as or peer-group commands first".
another question is "is it a must to have three routers(PE)?
Can it work with my sketch(only four routers.
Yes it can... you can remove the RR in my design
"Cannot configure the local system as neighbor".
This means that you are trying to use using the routers own ip address instead of the peer neighbor command.. just chnage this to the other peer
Narayan
Lawrence,
As the message indicates, you are trying to activate using the address of the local end when you should be using the remote end as defined in global bgp mode.
As to your other question, you can run mpls vpn with only two PEs, no P router.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Community Member
sorry my bad, you guys are correct but it's still giving me an errors message "Specify remote-as or peer-group commands first" when I try to activate the neighbor.
I am starting to suspect the ios. this router is using version 12.2(31)SB9, the other router is using version 12.4(21) and this one does accept this configs. i once tried to upgrade to the recent version but it's failing to boot from the latest..
Community Member
I forgot to put it the remote-as.. thanks for your help but I am still proceeding with my configs not done yet.
Hello Lawrence,
on older IOS version you need to give
router bgp 100
this is to be able then to use the address-families
Hope to help
Giuseppe
Community Member
now I can configure address-families, my other problem is I have configured bgp on my ce routers(R1&R4). and R1 neighbor is R4 on BGP and vice versa. vpnv4 is configured between the two PE router's(R2&R3).
Do I need to configure adress-families between R1&R2 and between R3&R4? is there another simple understandable method of creating multiple vpn
Lawrence,
You do not need to configure a BGP session between R1 and R4. You rather need to run a BGP session between R1 and R2 and another one between R3 and R4. These session would be in the VRF context (address-family ipv4 vrf xxx).
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
You need to advertise routes to the PE routers from both R1 and R4. You can choose any routing protool like ospf/ eigrp or BGP.
Best option would be to use BGP between the CE and the PE.
If you have followed the configurations i have posted then you can create multiple VPNs over the MPLS.. All you need to do is to create multiple VRFs in the PE routers and have subinterfaces towards the CE routers (each subinterface being part of a different vrf)
Narayan
Community Member
on the configs that you sent didn't you forget the neighbor statements on the PE's pointing towards the ce's?
there is communication between the PE and CE, I thought they will see each other from the address-family config that is on the PE's where the neighbor is specified.
right now only the PE's can see each other.
I am not sure whether u r using the same configs as i supplied
These are BGP configs between CE and PE
CE - R0
router bgp 2
no synchronization
network 100.100.100.0 mask 255.255.255.0
redistribute connected
neighbor 172.16.100.1 remote-as 1
no auto-summary
PE1 - R1
address-family ipv4 vrf abc
neighbor 172.16.100.2 remote-as 2
neighbor 172.16.100.2 activate
neighbor 172.16.100.2 as-override
no auto-summary
no synchronization
exit-address-family
Narayan
Community Member
on the PE1 under the router bgp 1, shouldn't there be a neighbor statement?
e.g
router bgp 1
Nope... it will have only the BGP session to the PE
The CE-PE BGP sessions shud be under the address-family
Narayan
Community Member
i used all your configs besides the ip addressing..
PE1
ip vrf VPN1:Mpho
rd 2:101
route-target export 2:101
route-target import 2:101
interface ATM1/0.100 point-to-point
ip address 165.148.122.2 255.255.255.252
ip ospf network broadcast
no atm enable-ilmi-trap
pvc 1/100
encapsulation aal5snap
interface ATM1/0.200 point-to-point
ip vrf forwarding VPN1:Mpho
ip address 10.0.0.2 255.255.255.252
pvc 1/200
router ospf 1
network 165.148.120.0 0.0.0.3 area 0
network 165.148.122.0 0.0.0.3 area 0
router bgp 200
no synchronization
neighbor 1.1.1.1 remote-as 200
neighbor 1.1.1.1 update-source Loopback0
no auto-summary
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 send-community both
exit-address-family
address-family ipv4 vrf VPN1:Mpho
no auto-summary
no synchronization
exit-address-family
CE1
ip vrf VPN1:Mpho:Aggr
rd 2:2002
route-target export 2:2002
route-target import 2:2002
interface ATM3/0.100 point-to-point
ip address 165.148.122.1 255.255.255.252
pvc 1/100
interface ATM3/0.200 point-to-point
ip vrf forwarding VPN1:Mpho:Aggr
ip address 10.0.0.1 255.255.255.252
pvc 1/200
router ospf 1
network 2.2.2.2 0.0.0.0 area 0
router bgp 100
no synchronization
network 2.2.2.2 mask 255.255.255.255
neighbor 165.148.122.2 remote-as 200
no auto-summary
Hello Lawrence,
just a moment
for the Ce router the BGP session needs to be in the global routing unless it is a multi VRF CE
if it is a multi VRF CE the neighbor sessions have to be configured on both devices under address-family ipv4 vrf-name
what decides what to here is the table where the link between the two stay:
VPN1:Mpho on Pe side
VPN1:Mpho:Aggr on CE side
the neighbor are 10.0.0.2 for PE and 10.0.0.1 on the CE side
Hope to help
Giuseppe
Community Member
right now I only need to get a single vrf up and running so at this stage it's not a multi vrf. I am going to take an hour nap, I will be back in an hour..
I have removed the other sub interface with that 10.x.x.x ip. I only left the sub-int with 165. ip add. my worry is i think I have done everything correctly but just when I apply the ip vrf on that sub-inter, she dont like it and she drops. both ce's.
Community Member
I still can't get it right.. I tried all the methods but I truly don't know what is it that I am doing wrong...
I need to know this if they say "if BGP is the routing protocol" and "if bgp is not the routing protocol" how do you differentiate between the two in my case?
if you need to refer here is the url where I got this statements.. http://www.cisco.com/en/US/docs/ios/12_2sb/feature/guide/vrflitsb.html
Hello Lawrence,
with multi VRF CE you use a dedicated link in VRF between the multi VRF CE and the PE.
A multi VRF CE has a subset of PE features and functionalities: actually it allows to define VRFs to associate interfaces to different VRFs and to run routing protocols in the VRF -aware version.
With a dedicated link a VRF defined on the PE is put in communication with a VRF defined on the CE and VRF segregation is extended to a shared CE (shared by different customers)
What is the protocol you are going to use on the link PE-CE ?
if it is BGP you need to follow the EBGP PE-CE model on both sides:
actually the CE will be a neighbor in VRF PE_VRF
router bgp 100
address-family ipv4 vrf PE_VRF
neigh 165.1.1.2 remote-as 65000
neigh 165.1.1.2 activate
neigh 165.1.1.2 send-community
red conn
red static
the link must be associated to VRF PE_VRF on the PE
int atm x/y/z.m
ip vrf forwarding PE_VRF
ip address 165.1.1.1 255.255.255.252
on the CE as a mirror the PE is seen as a CE:
ip vrf CE_VRF
rd 65000:100
int atm x/y/z.m
ip vrf forward CE_VRF
ip address 165.1.1.2 255.255.255.252
router bgp 65000
address-family ipv4 vrf CE_VRF
red conn
red static
neigh 165.1.1.1 remote-as 100
neigh 165.1.1.1 activate
neigh 165.1.1.1 send-community
I would suggest you to start from a normal CE without any VRF defined on it and then you can move to this
As a third step you can try to use OSPF as the PE-CE protocol in multi-VRF context but this comes later
clean up all the config from ospf commands and other options
Very important note:
when you associate an interface to a VRF its ip address is removed and you need to retype it, even if you want to keep the same address it had in global routing table
Hope to help
Giuseppe
Community Member
I want a ce to be a customer at this stage, then I will run multi vrf at a later stage no vrf configuration on the ce at this stage. I will attach my configs on one side meaning from PE to CE on one end. Please see if you can spot any mistake or problem. the ip address 1.1.1.1 is for R3(PE)
The only problem is once I configure IP vrf forwading on the interface towards the ce(ATM1/0.100) the bgp drops on that link and the ce is not pingable until I remove that command.
R2(PE)
interface Loopback0
ip address 4.4.4.4 255.255.255.255
mpls bgp forwarding
pvc 1/100
ip address 165.148.120.2 255.255.255.252
mpls ip
pvc 1/100
router ospf 1
router bgp 1000
neighbor 1.1.1.1 remote-as 1000
neighbor 165.148.122.1 remote-as 6500
address-family ipv4
redistribute ospf 1
neighbor 165.148.122.1 activate
no auto-summary
no synchronization
exit-address-family
neighbor 1.1.1.1 send-community extended
exit-address-family
neighbor 165.148.122.1 send-community
no auto-summary
no synchronization
exit-address-family
R1(CE)
interface Loopback0
ip address 2.2.2.2 255.255.255.255
pvc 1/100
router bgp 6500
no synchronization
neighbor 165.148.122.2 remote-as 1000
no auto-summary
Lawrence,
You don't need "mpls bgp forwarding" on ATM1/0.100 but you absolutely need the "ip vrf forwarding " command. The BGP session that is going down when you enter the "ip vrf forwarding" on the sub-interface is the BGP ipv4 session. This session should be removed.
router bgp 1000
address-family ipv4
no neighbor 165.148.122.1 activate
If you want to see the bgp session to the PE, do a "show ip bgp v a summ".
You say that the PE is not pingable, did you try ping vrf 165.148.122.1?
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Community Member
no the CE is not pingable., and remember there is no vrf configured on the CE...
653
