Community Member
Redistribution eBGP/MPLS to EIGRP- Companies Migration
I have a question about two companies migration Iusse, Attached scenario should give most of the information.
Company A got two router R1 and R2 running EIGRP100 with the service providers 1
Company B got R3 Running MPLS BGP with same service provider 1
Company A is migrating with Company B
After migration Company A and B should be takling internally
With the Below Configuration, I can reach from company A to B, but Not from Company B router to Company A Not sure what I am missing in my configs  Or is there a better way to migrate two copmanies with out creating new EIGRP AS?
Company A Router 1
router eigrp 100 <----To ISP 1
redistribute connected
no auto-summary
eigrp router-id 10.10.10.1
network 10.0.0.0
network 172.17.10.0 0.0.0.3
router eigrp 200          <---- to Company B
no auto-summary
eigrp router-id 192.168.200.5
network 172.16.10.0 0.0.0.3
Company A-R1#ping 192.168.200.1- This is in VRF on Router CompanyB
Sending 5, 100-byte ICMP Echos to 192.168.200.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Company B Router configuration
How can I redistribute the routes learned [through redistribute connected/static] into EIGRP 200
router eigrp 200( built new EIGRP 200 to get routes from Company A and keep them seperate)
redistribute bgp 200 metric 10000 2000 255 1 1500
no auto-summary
eigrp router-id 192.168.200.1
router bgp 200          <-----eBGP to ISP 1
bgp router-id 172.15.10.1
bgp log-neighbor-changes
address-family ipv4
  no auto-summary
  no synchronization
exit-address-family
address-family ipv4 vrf test1
  redistribute eigrp 200
  neighbor 172.15.10.2 remote-as 54321
  neighbor 172.15.10.2 update-source Vlan555
  neighbor 172.15.10.2 activate
  neighbor 172.15.10.2 soft-reconfiguration inbound
  no synchronization
  network 10.50.60.0 mask 255.255.255.192
  network 172.15.10.0 mask 255.255.255.252
  network 192.168.200.0 mask 255.255.255.252
exit-address-family
company B#ping 192.168.200.5
Sending 5, 100-byte ICMP Echos to 192.168.200.5, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
R4#ping 192.168.200.1
Can someone guide me what I am doing wrong?
Hi Blanch,
1. I need a lot more information to tell you whats going on:
-- Complete configs of all 3 routers would be good (here even the inteface configs aren't there)
-- "show ip route" and "show ip cef "for the prefixes which you're pinging
-- traceroute to the prefixes as well
2. You say that when you're pinging 192.168.200.1 from Router 1 , that the IP resides on Router 2 in  a vrf. Fair enough.
However, when you do a reverse ping, I don't see "ping vrf [vrfname] 192.168.200.5"
Also, if that interface is in a vrf on Router 2, and eigrp 200 is running over it, then we should have the configs under the address-family for that vrf in eigrp, which i don't see here.
3. Also send outputs of show ip eigrp neigh
Blach,
I hope you remember me. I replied to this post when you posted this question sometime ago. I am sorry I couldnt get back to you on that again. got caught up with stuff.
https://supportforums.cisco.com/message/3546688#3546688
now, the solution is very simple. If you re-visit that thread again, varma gave you the answer. Below is what you need to configure on Company B R1 router.
router eigrp 200
no auto-summary
address-family ipv4 vrf "VRF_Name"
no auto-summary
exit-address-family
Let me explain it to you. Your company B R1 router is acting like a  PE. and this case the Compan A R1 acts like a CE and they peer using the  eigrp 200 AS.
So you dont need to create any VRF's etc on company A R1. Just put the above config and it should work.
So, when you ping from the company B R1 to the company A R1 just use the ping vrf  VRF_Name" command.
The way around you dont need to use the vrf
Kishore
320
