Webcast-Catalyst9k
redistribution of static routes into EIGRP
Hi all,
I got few questions regarding redistribution of static routes into EIGRP:
1 - Can I use sequenced access list with route-map to control which routes are being redistributed? For example, would following config stop any route towards 10.0.0.0/8 being redistributed:
ip access-list standard filter-static
10 deny static 10.0.0.0 255.255.255.0
100 permit any
route-map STATIC permit 10
match ip address filter-static
router eigrp 100
redistribute static route-map STATIC
2- In config example 1 (if it works) if I update access list "filter-static" would I need to re-create route-map "STATIC" and/or to reapply it to eigrp process static redistribution or it will be updated dynamically?
Sasa
Re: redistribution of static routes into EIGRP
Sasa,
The configurations would be updated dynamically if the access-lists are modified.
The access-list however use a inverse mask and hence it should be
Access-list 10 deny 10.0.0.0 0.255.255.255
access-list 10 permit any
I have this setup in my network and i keep adding the access list statements w/o resetting the EIGRP.
Your Configuration shoulf work fine
HTH, rate if it does
Narayan
Hi Narayan,
Thanks for your reply.
However, my question was more specifically regarding sequenced access-list, while in your exaple you are using standard access-list. So far, on internet or in any of the books I have, I did not find a single example using sequenced access-list with route-map.
And, yes, you are right regarding the mask, I ment to inverse 255.0.0.0 and for some strange reason put totali wrong mask :( - I hope my brain will be switched on, when I do this on my production router.
Sasa
Sasa,
It would work fine. If your code supports ACL sequence numbering then there is no problem.
Support for the same started from 12.2(14)S
All a route-map does is just refernce the access-list
Narayan
Great, this is answer I was looking for.
Sasa
352
