Silver
Redistribution problem.
Hi Experts ,
The setup is as follows.
RTRA(eigrp)-RTRB(a0)-RTRC(a0+a66)-RTR D(a66)
RTR E
All the routers are conncected using serial links.
RTR A is running Eigrp and RTRB, RTR C and RTR D are running ospf.
10.0.0.0 /8 network is used on RTR a and RTR E whereas 172.0.0.0 /8 is used on the remaining Routers.
I am trying for redundency in this scenario.
My problem is,
172.29.140.0 / 25 network is allocated to RTR D.172.29.140.25 is allocated to ATM.
RTR D is the backup for this ATM ( VSAT connectivity).
Whenever serial link b/n RTR C and RTR D goes down , then traffic should take path through RTR E.(i.e RTR A to RTR E to reach ATM on VSAT link).
I have configured the following routes on RTR A which is running Eigrp.
ip route 172.29.140.25 255.255.255.255 172.16.17.1
ip route 172.29.140.25 255.255.255.255 10.30.0.126 120.
Where 172.16.17.1 is serial ip of RTR B and 10.30.0.126 is serial ip of RTR E.
As soon as I shutdoen the serial link of RTR C which is connecting to RTR D , we are getting ospf updates till RTR B.Where as the static route configured on the RTR A is not purging out from RTR A route table so that floating static route will come in to picture.
static routes are redistibuted on RTR A and RTR B under Eigrp (RTR A) and OSPF (RTR B).
Whenever I shutdown serila link of RTR C , ospf updates on RTR B , RTR C are not showing 172.29.140.0 subnet and statis route on RTR A is still pointing towards RTR B not to RTR D.
What could be the problem.How to achieve redundency in this case.
1 REPLY
Silver
Re: Redistribution problem.
Sorry for the mistake made in the previous post.
Actually i am making serial link of RTR C is down which is connecting to RTR D , so that floating static route configured on RTR A comes into picture and traffic will be through RTR E instead of RTR B.
But as soon as i shut the serial interface of RTR C , the static on RTR A is not vanishing from routing table of RTR A.
The ouptut taken on RTR A and RTR B without shutting down the serail link of RTR C are.
RTR A#sh ip route 172.29.140.25
Routing entry for 172.29.140.0/25
Known via "static", distance 1, metric 0 (connected)
Redistributing via eigrp 15
Advertised by eigrp 15
Routing Descriptor Blocks:
* 172.16.17.121
Route metric is 0, traffic share count is 1
and
RTR B#sh ip route 172.29.140.25
Known via "ospf 192", distance 110, metric 1954, type inter area
Redistributing via rip
Advertised by rip metric 10
Last update from 172.16.0.5 on GigabitEthernet5/2, 00:00:31 ago
* 172.16.0.5, from 192.168.254.16, 00:00:31 ago, via GigabitEthernet5/2
Route metric is 1954, traffic share count is 1
As soon as i make the serial link of RTR C which is connecting to RTR D , the above route to 172.29.140.25 should go off and floating static route should be prrsent in the routing table of RTR A which is not happening in this case.
Thanks....
99
