Community Member
redistribution rip metric
Hi Experts,
I am puzzling with this..I have this router eigrp config as below but is WITHOUT Router RIP command. So, what is the command " redistribute rip metric 15000 500 255 1 1500 " for if that is the case?
router eigrp 10
passive-interface default
no passive-interface Serial2/0
no passive-interface Serial2/1
no passive-interface Serial2/2
no passive-interface Serial2/3
network 13.31.0.0 0.7.255.255
auto-summary
Thanks in advanced!
1 ACCEPTED SOLUTION
Community Member
Re: redistribution rip metric
that is correct.
if in doubt use
sho ip route summ
this will show you all routing protocols in use and prefixs.
Community Member
I would have a guess and say nothing. Its often the case commands like this are left in after clean ups or migrations and someone didnt take it out.
If no routing process is running then the redist command will not perform a function on that named process unless it exists.
If RIP is not being used, you can go ahead and remove this configuration
Narayan
Community Member
Thanks Robert! for your quick response!! :D
,can i say even another router connected to the core switch together with this router having RIP, this command doesn;t serve any purposes on this particular router?
Community Member
Thanks Narayan! :)
so, the same question will be what i posted to Robert..If that is the case, i can proceed to remove this and if there is "redistribute static metric" but NO STATIC ROUTE Existed,
i can also remove this command rite? ;)
Thanks.
Yes you are correct
Narayan
Community Member
Thanks guys..
post rated!! :D
Community Member
that is correct.
if in doubt use
sho ip route summ
195
