redistribution
I have following problem:
I redistribute RIP with default route to iBGP. Then other side of network I have to redistribute those routes (including default route) back to RIP. Every route redistributes back to RIP except the default one. Does anyone know how to redistribute default route from iBGP to RIP?
Thanks in advance
Re: redistribution
Antonio,
You shouldn't need any special configuration to redistribute default route from IBGP-->RIP as the other IBGP routes are getting redistributed. The default route on the router you are doing IBGP-->RIP redistribution mightn't be an IBGP route. Perhaps, it's a static default route or route from another source. If you are still having issues, can you share the output of show ip route 0.0.0.0 from the router doing redistribution.
Sundar
Re: redistribution
Hello Sundar,
Here is the output :
sh ip route 0.0.0.0
Routing entry for 0.0.0.0/0, supernet
Known via "rip", distance 120, metric 2, candidate default path
Redistributing via bgp X, rip
Advertised by bgp X
Last update from 11.0.0.50 on Vlan111, 00:00:12 ago
Routing Descriptor Blocks:
* 11.0.0.50, from 11.0.0.50, 00:00:12 ago, via Vlan111
Route metric is 2, traffic share count is 1
And here is the conf:
router rip
version 2
no auto-summary
redistribute bgp X metric transparent
network 11.0.0.0
router bgp X
redistribute connected
redistribute static
redistribute rip
default-information originate
no auto-summary
no synchronization
On the second router where I redistribute BGP to RIP is simmilar configuration.
Am I doing something wrong in configuration?
thanks
Re: redistribution
I forgot to send output from the second router (where I redistribute BGP back to RIP)
#sh ip route 0.0.0.0
Known via "bgb X", distance 200, metric 2, candidate default path, type internal
Redistributing via rip
Advertised by rip metric transparent
Last update from 10.0.0.5 00:02:17 ago
* 10.0.0.5 (Default-IP-Routing-Table), from 10.0.0.5, 00:02:17 ago
AS Hops 0
Re: redistribution
Antonio,
Can you post the configuration of the router redistributing iBGP into RIP.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Re: redistribution
Antonio,
Do you have "bgp redistribute-internal" configured under "router bgp x" on the router where you redistribute from iBGP to RIP?
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Re: redistribution
Nevermind my last question. You probably do since the other routes are redistributed back into RIP.
Cheers,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Re: redistribution
Antonio,
I was about to post this information but Harold beat out in posting this info. As Harold stated, you need to configure this command under the BGP process to redistribute IBGP into IGP, RIP in your case.
router bgp xxxx
Though, you indicated you see other IBGP routes being redistributed into RIP, I am guessing those all might be static/connected routes rather than IBGP routes since you are redistributing them as well.
Let us know if you have this command configured and are still having issues.
Sundar
Re: redistribution
Yes I have that command, but default route is still missing in RIP-e
Re: redistribution
I had tried your setup in my lab and the default route was getting redistributed. The only difference in my setup was I had 'redistribute bgp X metric 2' under the RIP process instead of the transparent metric. Configure this and enable 'debug ip rip' and post the output here, if that doesn't help.
Moreover, can you share the full config of the router doing IBGP-->RIP redistribution and 'show ip route summary'.
Re: redistribution
What version of IOS are you running on the router redistributing iBGP into RIP?
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
136
