11-21-2011 06:41 AM - edited 03-04-2019 02:21 PM
Our current router is setup to redistribute our BGP routes into OSPF using the following code:
router ospf 60
log-adjacency-changes
redistribute bgp 65199 metric 1500 metric-type 1 subnets
I want to filter down the routes so only a set of specific routes is redistributed.. we have done this in the past with EIGRP by doing a route-map / prefix-list to manage the routes passed into EIGRP.
My question is I can replicate the metric and the metric-type in the route-map by doing the following:
route-map bgp-to-ospf permit 10
match ip address prefix-list bgp-to-ospf
set metric 1500
set metric-type type-1
router ospf 60
redistribute bgp 65199 route-map bgp-to-ospf
Do I need to be concerned witht the "subnets" command in this design? What I understand "Subnets" =
When redistributing routes into OSPF, only routes that are not subnetted are redistributed if the subnets keyword is not specified. I suspect I need to add it! So my final code should look like this.. is this correct?
set metric 1500
router ospf 60
redistribute bgp 65199 route-map bgp-to-ospf SUBNET
Solved! Go to Solution.
11-21-2011 06:45 AM
Your concern is correct. Otherwise, you will get only major networks.
HTH,
Toshi
11-21-2011 06:45 AM
HTH,
Toshi
11-21-2011 06:58 AM
Thank you for confirming this for me!
