Community Member
Redundancy and Failover setup for 2 MPLS link with 2 different countries
Hi Sir/Madam,
We have 2 MPLS link and both links are active (from COUNTRY A to COUNTRY B) and we also have 2 partners who are located in COUNTRY B with same building but with different offices and each partner will be using each MPLS link.  For example, PARTNER A will use the 1st MPLS link and PARTNER B will use the 2nd MPLS link and we want to have a failover setup (please see sample design below).  What is the best solution for COUNTRY A and B to have a full redundancy and failover setup/network?
Any recommendation and sample configuration will be a big help for me.   Your feedback is highly appreciated.
Thank you in advance.
Best regards,
Everyone's tags (1)
Super Bronze
DisclaimerThe Author of this
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
MPLS links, eh.  You mean your MPLS facing ports have actual MPLS labels?  Or do you mean your WAN links are running across a MPLS network, but the handoff isn't MPLS?
Country A's two routers are your company's devices?  Do you have interior connectivity between them?
Country B's two routers - do they or can they have interior connectivity?
What routing protocols are being used (and where)?
