10-18-2013 03:24 PM - edited 03-04-2019 09:21 PM
is there any soultion to replicate two 2911 routers for redundancy?
Solved! Go to Solution.
10-19-2013 03:34 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Hardware redundancyif one unit fail the other one connected to the same switch will handle traffic.
Yes, although then the switch becomes a single point of failure. That might be addressed with multiple switches and/or stackable switches.
10-19-2013 02:57 AM
Disclaimer
Posting
Could you clarify what kind of redundancy you're looking for?
For small ISRs like 2911, redundancy is usually provided by having two (or more) with multiple L3 links and/or FHRP (i.e. HSRP, VRRP).
10-19-2013 03:03 AM
Hardware redundancy
10-19-2013 03:34 AM
Disclaimer
Posting
