Redundancy/Load balancing 2 x Frame-relay
Currently have all static routing for a network of 14 sites.
-All sites have 2 x Frame T1's to Core site.
-All sites have local T1 ISP.
Remote site frame config looks like this:
interface Serial0
description connected to CORE Frame Network
no ip address
encapsulation frame-relay IETF
no fair-queue
service-module t1 timeslots 1-24
service-module t1 remote-alarm-enable
frame-relay lmi-type ansi
interface Serial0.1 point-to-point
description connected to Core Frame 1
ip address 172.16.20.2 255.255.255.252
frame-relay interface-dlci 50 IETF
interface Serial0.2 point-to-point
description connected to Core Frame 2
ip address 172.16.21.2 255.255.255.252
frame-relay interface-dlci 60 IETF
Remote site routing looks like this:(172.16.25.1 is PIX firewall)
ip route 0.0.0.0 0.0.0.0 172.16.25.1
ip route 0.0.0.0 0.0.0.0 172.16.20.1 2
ip route 0.0.0.0 0.0.0.0 172.16.21.1 3
ip route 10.0.0.0 255.0.0.0 172.16.20.1
ip route 10.0.0.0 255.0.0.0 172.16.21.1 2
ip route 10.0.0.0 255.0.0.0 172.16.25.1 3
So, we have 3 possible links to get each site to the CORE site.
Want advice on best solution for load-balancing and quick failover in event of circuit outage.
Which way would you do it?
1 REPLY
Re: Redundancy/Load balancing 2 x Frame-relay
EIGRP would be a good choice for your network. EIGRP is not that difficult to set up and best suited to hub-and-spoke network like yours.
Leave the static default route as it is at every remote to route traffic to the ISP through the firewall. Run EIGRP on your hub and remote routers. Increase EIGRP delay for the link between core2 and spoke and that link would be used when all other options become unavailable. Inject a default route from the hub routers to your spokes.
Pls. rate the post if it helped.
HTH,
Sundar
88
