Redundant fiber connection
dyorke0403
Is is possible to setup two incoming fiber links from a 6509 to a 3750. The goal is to setup a redundant fiber link should 1 gbic go bad (example). Is what I am describing GB ether channeling? Seems like this would create a spanning tree loop and yet it seems this should be possible. Any thoughts appreciated!
6 Replies 6
Giuseppe Larosa
Hello Daniel,
if you don't configure them on both ends to be part of an etherchannel STP will block one link.
STP is able to deal with link redundancy and technically it is better to speak of bridging loops because STP has been thouoght to avoid them.
if both are fiber links you can bundle them you will get redundancy and more bandwidth.
Hope to help
Giuseppe
Thanks for the quick response!
For clarification: Are you saying I should only set the ether-channel up on one end for each fiber? Does it matter which end (3750 or 6509)that I set it up on?
Collin Clark
You could create an etherchannel which "bonds" them together creating a 2 gig channel. If a link fails, the channel stays up because it still has one good link left. From a spanning tree perspective, it's a single link. You can also run to separate fiber cables and have spanning tree block one of them, preventing a loop. If the active one fails, the other will become active and forward traffic. In the second scenario there could be a small outage as STP converges.
Hope that helps.
////////6509////////
interface GigabitEthernet10/10
no ip address
switchport
switchport mode trunk
spanning-tree portfast disable
channel-group 25 mode on
interface GigabitEthernet11/10
no ip address
switchport
interface Port-channel25
no ip address
switchport
//////ON 3750////////
interface Port-channel1
interface GigabitEthernet1/0/49
channel-group 1 mode on
interface GigabitEthernet1/0/50
Thanks to all who responded. Applied this weekend and it's working out very well. Appreciate the help!
