redundant internet - fail over santiy check
hello,
I'm sure this has been asked a few times,  but I thought there may be newer options..
I am putting a list of parts and licenses we'll need to build a more redundant internet connection.  Currently we own:
1x ASR 1004 (edge)
2x ASA 5580-20 (fw)
1x 6509e  (core)
2 ISPs.
I think we'll need to order a few switches.  in the near future we'll have 10Gbit connections to the ISPs,  meaning i'll want a switch that is 10Gbit ready today.
my questions:
is this the way we would connect things up?
do i need any licenses beyond what ships with the hardware?
which switch would you recommend?
any other general advise would be great,  thanks.
take care,
greg
Re: redundant internet - fail over santiy check
Hi Gregory
The above 10G connection with SP , I won't understand. ( 10 G  WAN link )
==>Please refer the diag.
==> No, But if you need SSL VPN then you need to buy licenses.
==> 3750G For 10 Gig
If you have plan to deploy 10 Gig , Then please check the ASA 5540 & ASR ( You requried additional interface card )
http://cisco.biz/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/product_data_sheet0900aecd802930c5.html
You had mention that currently  you have
1x ASR 1004 (edge)
2x ASA 5580-20 (fw)
1x 6509e  (core)
2 ISPs.
But in you diag there are two edge devices.
Chetan Kumar
hello Chetan,
the current port speed to both ISPs is 1Gbit.   We'll be upgrading to 10Gbit at some point in the future.
the diagram shows two edge routers just to show you how I thought things might be connected.   we do not own everything yet.
I understand the ASR and ASA will both require 10Gbit interfaces,  thanks.
in your picture,  the configuration on the right,  it appears as if there is only one path per router from the switch.  was this an accident or is that how it should be connected?  if you were to lose one of the routers,  you would also lose a path to one of the ISPs.
The idea is we could lose any 1 device between the 6500 and the ISP and still have a path to both ISPs.
thanks for the info on the 3750-10G Chetan.
I forgot to draw two cables between switch & router. It was accident please make correction.
And as you mention you are upgrading 1 gig to 10 Gigi wan interface , But really you requried ( I don't think so ) .
Please refer the new diag
The red line show the traffic flow & other side will be standby ( Switch, router, ASA will be in standby ) . And vice versa for failover, Entire traffic will shift to other side.
Chetan Kumar
Thanks for clearing that.
"... you are upgrading 1 gig to 10 Gigi wan interface , But really you requried ( I don't think so ) ."
you don't think my organization requires 10Gbit...    Are you familiar with what we do?
thanks for your help again,
greg
It is up to you weather you want to upgrade 1 gig to 10 gig. If your company requried then definetly you can go, Its completely your choice.
Chetan Kumar
281
