Redundant WAN route selection with BGP and OSPF redistribution
jvanderson2010
I have a requirement to implement a redundant WAN solution with BGP and OSPF redistribution, and I've got to a point that is getting beyond my knowledge and am after some assistance / guidance.
To [hopefully] set the scenario, see the attached / included diagram.
For the remote site, I want the primary WAN connection back to the main site to be the Telco WAN cloud.  Under normal network all traffic to and from the Remote Site and Main Site should traverse the Telco WAN cloud.  In the event of a failure of the Telco WAN cloud, including a link failure at MLB-RTR or a link failure at B1H-RTR or a failure within the Telco WAN cloud, I want all traffic to fail-over to the backup link, which is the Microwave/radio link.
Across the Microwave backup link I only want a default route advertised from CEN-RTR, as the Main Site is where the default route should go to.
When the Telco WAN cloud connection is restored, I want all traffic to fail-back to the Telco WAN cloud connection from the Microwave/radio link.
My problem is that fail-over works fine, but fail-back does not work properly.
When I cause of failure of the Telco WAN connection by shutting down the WAN interface on MLB-RTR all the routing fails over to the Microwave/radio backup link.  However, when I bring that interface back up the fail-back does not work properly.  Both the MLB-RTR and TSB-RTR routers restore their original routing and send all traffic destined to the Main Site via the Telco WAN cloud.  However, the CEN-RTR and B1H-RTR do not restore their routing, and they continue to route traffic via the Microwave/radio backup link.  ie.  CEN-RTR continues to advertise into OSPF a path via redistributed BGP routes, and B1H-RTR prefers the routes to the remote site seen via OSPF over any routes it sees via BGP.  For some reason B1H is either not receiving the Remote Site routes via BGP upon restoration, or it is ignoring them in favour of the OSPF path.
To restore the routing back to "normal" via the Telco WAN cloud, I have to manually shutdown the CEN-RTR WAN interface, which causes the routes to disappear from OSPF and then B1H-RTR picks up the routes from the Telco WAN cloud.  Redistribution from BGP into OSPF by B1H-RTR then occurs and everything returns to normal.  After which I can bring back up the CEN-RTR WAN interface and everything stays "normal".
However, when I cause a failure of the Telco WAN connection by shutting down the WAN interface on B1H-RTR, all the routing fails over.  Then when I restore the interface, the B1H-RTR brings up the BGP neighbour successfully, and receives the routes to the Remote Site, and redistributes them into OSPF, which then become the preferred path in the OSPF network, and subsequently preferred by the CEN-RTR.  So routing restores back to "normal".
Below is copies of the relevant sections of configuration from the key four devices illustrated in the diagram and participating in the design.  I'm not BGP expert so this configuration may not be ideal and I'm open to suggestions for improvement.
B1H-RTR
interface Loopback0
ip address 172.27.127.247 255.255.255.255
interface GigabitEthernet1/0/1
description Telco WAN Cloud
no switchport
ip address 172.27.126.102 255.255.255.248
speed 100
duplex full
no mdix auto
interface Vlan582
description To Campus Network
ip address 172.27.126.114 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip ospf message-digest-key 1 md5 7 0225267F5F562B701C
ip ospf hello-interval 4
interface Vlan583
ip address 172.27.126.122 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
router ospf 1
log-adjacency-changes detail
auto-cost reference-bandwidth 10000
area 0 authentication message-digest
redistribute static metric 100 metric-type 1 subnets
redistribute bgp 64614 metric 10 metric-type 1 subnets route-map RM-BGP-TO-OSPF
passive-interface default
no passive-interface Vlan582
no passive-interface Vlan583
network 172.27.0.0 0.0.255.255 area 0
router bgp 64614
bgp log-neighbor-changes
timers bgp 1 3
neighbor 172.27.126.97 remote-as 64514
address-family ipv4
  redistribute connected
  redistribute static
  redistribute ospf 1 match internal external 1 external 2 nssa-external 1 nssa-external 2
  neighbor 172.27.126.97 activate
  neighbor 172.27.126.97 default-originate
  neighbor 172.27.126.97 weight 40000
  neighbor 172.27.126.97 soft-reconfiguration inbound
  neighbor 172.27.126.97 prefix-list PL-BGP-DROP-DEFAULT-ROUTE in
  neighbor 172.27.126.97 route-map RM-BGP-WEIGHT in
  distance 20 0.0.0.0 255.255.255.255
  distance 20 0.0.0.0 0.0.0.0
  no auto-summary
  no synchronization
  bgp redistribute-internal
  network 0.0.0.0
exit-address-family
ip prefix-list PL-BGP-DROP-DEFAULT-ROUTE description DO NOT ACCEPT THE DEFAULT ROUTE FROM THE GWIP CLOUD
ip prefix-list PL-BGP-DROP-DEFAULT-ROUTE seq 10 deny 0.0.0.0/0
ip prefix-list PL-BGP-DROP-DEFAULT-ROUTE seq 20 permit 0.0.0.0/0 ge 1 le 31
route-map RM-BGP-WEIGHT permit 10
set local-preference 40000
set weight 40000
route-map RM-BGP-TO-OSPF permit 10
set tag 666
CEN-RTR
interface Loopback0
ip address 172.27.127.248 255.255.255.255
interface Vlan563
description Microwave backup link
ip address 172.27.126.69 255.255.255.248
no ip proxy-arp
ip ospf message-digest-key 1 md5 7 013024200F5B225E71
arp timeout 300
router ospf 1
redistribute static subnets route-map STATIC_TO_OSPF
redistribute bgp 64614 metric 1000 subnets route-map RM-BGP-TO-OSPF
no passive-interface GigabitEthernet1/4
no passive-interface Vlan3
no passive-interface Vlan67
no passive-interface Vlan559
no passive-interface Vlan561
no passive-interface Vlan562
network 10.127.0.0 0.0.255.255 area 0
network 10.176.0.0 0.0.255.255 area 0
network 192.168.0.0 0.0.255.255 area 0
router bgp 64614
timers bgp 1 3
neighbor 172.27.126.68 remote-as 64616
address-family ipv4
neighbor 172.27.126.68 activate
neighbor 172.27.126.68 default-originate
neighbor 172.27.126.68 prefix-list PL-BGP-DROP-DEFAULT-ROUTE in
neighbor 172.27.126.68 route-map RM-BGP-WEIGHT in
neighbor 172.27.126.68 route-map RM-BGP-ROUTES-OUT out
neighbor 172.27.126.68 filter-list 1 out
distance bgp 190 200 1
distance 190 0.0.0.0 255.255.255.255
distance 190 0.0.0.0 0.0.0.0
no auto-summary
no synchronization
network 0.0.0.0
exit-address-family
ip as-path access-list 1 deny .*
ip prefix-list PL-BGP-DROP-DEFAULT-ROUTE description DO NOT ACCEPT THE DEFAULT ROUTE FROM THE BACKUP LINK
route-map STATIC_TO_OSPF permit 20
set metric 140
set metric-type type-2
route-map RM-BGP-ROUTES-OUT permit 10
set metric 200
set as-path prepend 64614 64614 64614
set weight 1
set weight 1
MLB-RTR
interface FastEthernet2/0/24
no switchport
ip address 172.27.126.110 255.255.255.248
speed 100
duplex full
no mdix auto
spanning-tree portfast
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
interface Vlan568
description Campus Network Routing
ip address 172.27.127.178 255.255.255.248
no ip proxy-arp
ip ospf message-digest-key 1 md5 7 123A2733465B28557A
router ospf 1
redistribute bgp 64616 metric 100 metric-type 1 subnets route-map RM-BGP-TO-OSPF
no passive-interface Vlan568
network 0.0.0.0 255.255.255.255 area 0
default-information originate
router bgp 64616
timers bgp 1 3
neighbor 172.27.126.105 remote-as 64516
neighbor 172.27.127.179 remote-as 64616
address-family ipv4
  redistribute static
  redistribute ospf 1 route-map RM-OSPF-TO-BGP
  neighbor 172.27.126.105 activate
  neighbor 172.27.126.105 weight 40000
  neighbor 172.27.126.105 prefix-list PL-BGP-DROP-DEFAULT-ROUTE out
  no neighbor 172.27.127.179 activate
  distance bgp 20 20 1
  no auto-summary
  no synchronization
  network 0.0.0.0
exit-address-family
set metric 130
route-map RM-OSPF-TO-BGP deny 10
match tag 666
route-map RM-OSPF-TO-BGP permit 20
set weight 40000
set tag 666
TSB-RTR
interface Loopback0
ip address 172.27.127.243 255.255.255.255
interface Vlan563
ip address 172.27.126.68 255.255.255.248
no ip proxy-arp
arp timeout 300
interface Vlan568
ip address 172.27.127.179 255.255.255.248
no ip proxy-arp
router ospf 1
redistribute bgp 64616 metric 1000 metric-type 1 subnets route-map RM-BGP-TO-OSPF
default-information originate metric 1000
router bgp 64616
timers bgp 1 3
neighbor 172.27.126.69 remote-as 64614
neighbor 172.27.127.178 remote-as 64616
address-family ipv4
  redistribute static
  neighbor 172.27.126.69 activate
  neighbor 172.27.126.69 prefix-list PL-BGP-DEFAULT-ROUTE-ONLY in
  no neighbor 172.27.127.178 activate
  no auto-summary
  no synchronization
exit-address-family
ip prefix-list PL-BGP-DEFAULT-ROUTE-ONLY description ONLY ACCEPT A DEFAULT ROUTE FROM RADIO LINK
ip prefix-list PL-BGP-DEFAULT-ROUTE-ONLY seq 10 permit 0.0.0.0/0
set metric 130
match tag 666
set weight 1
set tag 666
28 Replies 28
vikz230884
Hi John,
Looks like the traffic from B1H will choose to route to CEN since it have less as-path, because with telco router you run different AS.
I can think one of the solution is to prepend the as-path at CEN, so the route calculation will be based on weight & local preference (which you have already configured).
HTH,
Vikram
Vikram,
Does the AS-PATH come into the equation in this situation because there is no BGP peer between CEN and B1H?  It is only an OSPF cloud.
Thanks.
John,
My mistake, I initially tought that there is iBGP between them.. you're right..then when you're bringing the link, you need to see if there is actually routes advertise by the peer.
Are the show ip bgp, showed the routes with *> ?
I think the reason it still using the OSPF routes is because the routes from eBGP is not valid or there is no routes advertise from that peer...
HTH,
Vikram
milan.kulik
Level 10
Level 10
mutual BGP/OSPF redistribution is tricky sometimes.
You need to think about WHAT you are redistributing and WHEN you are redistributing.
IMHO, you problem on  B1H-RTR might be following:
When the Telco connection fails, the Remote site eBGP prefixes are removed from the BGP table.
The same prefixes are received via OSPF then and redistributed to BGP.
Note: BGP is using a default weight attribute value of 32768  for the prefixes redistributed in this scenario.
When the Telco connection is restored again, the Remote site prefixes are received again from eBGP.
But as the same prefixes are present in the BGP table already (redistributed from OSPF) with weight=32768 and they are beating the eBGP prefixes at the moment!
So B1H keeps the redistributed prefixes as the bets ones within BGP and keeps routing via OSPF consequently.
You can check using sh ip route and sh ip bgp x.x.x.x for one of the Remote site prefix at that moment - I guess you will see the weight value 32768.
So if I'm correct, you need to add a route-map with set weight 0 command to the B1H config for OSPF to BGP redistribution.
I'm not sure this will fix all problems in your design as it's quite complex.
But as I said, you need to think "What happens when the prefix comes from this side first and what happens if the prefix comes from the other side first?".
HTH,
Milan
Hello.. I have been facing same problem and i did try to set weight 0 while redistributing from ospf to BGP but still routes see from ospf. I had to clear ospf process to learn routes from BGP.
I want to know if some one had been facing similar issue and was able to fix this problem.
This is very tricky issue.
IMHO, you need to check why the prefixes redistributed from OSPF are still beating the same prefixes received from the BGP neighbor now.
Possibly another BGP attribute needs to be modified?
I remember similar case when I had to increase Local Preference of the prefixes received from the BGP neighbor to force them to win.
Best regards,
Milan
I would try increasing LP in another downtime window. Would like to know whether in your case increasing value of LP resolved this problem.
hi.. i tried with manipulating local preference, i confrigured LP value 50 while redistributing from ospf to BGP but still ospf routes is choosen.
What else can do to resolve this case as it seems a bit complex.
can you provide
sh ip bgp subnet/length
example of one of the prefixes which is still chosen redistributed from OSPF and also received via BGP at the same time?
The BGP attributes  should be visible in such an output and we should be able to see why the redistributed prefix was chosen.
BR,
Milan
pls see below output.
Incase of Mpls down i receive routes from ospf(fine int this case) but when mpls up still i see this route. I only see this route from ospf only.
MPLS#sh ip bgp 192.168.242.254
BGP routing table entry for 192.168.242.0/24, version 27328
Paths: (1 available, best #1, table default)
  Advertised to update-groups:
  Local
    192.168.80.17 from 0.0.0.0 (192.168.80.22)
      Origin incomplete, metric 2, localpref 50, weight 50, valid, sourced, best
MPLS#sh ip o ne
Neighbor ID     Pri   State           Dead Time   Address         Interface
192.168.199.254   1   FULL/DR         00:00:31    192.168.80.17   GigabitEthernet0/1
But when i reset ospf i started seeing below route.
BGP routing table entry for 192.168.242.0/24, version 27034
4755 4755
    172.16.0.17 from 172.16.0.17 (192.168.231.212)
      Origin incomplete, localpref 100, weight 200, valid, external, best
  4755 4755, (received-only)
      Origin incomplete, localpref 100, valid, external
MPLS#sh ip bgp summ | b N
Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
172.16.0.17     4         4755    8940    8967    27815    0    0 5d14h          63
so it seems to me:
You are advertising the OSPF prefix 192.168.242.0/24 to your BGP neigbor 172.16.0.17, aren't you?
And when MPLS is Up again, that neighbor is still not advertising 192.168.242.0/24 to you, i.e., it keeps the 192.168.242.0/24 prefix received from you as the best one even when MPLS is up?
In that case, you need to advertise the 192.168.242.0/24 prefix to the 172.16.0.17 neighbor with some worse BGP attributes to make the neighbor to prefer 192.168.242.0/24  prefix received from MPLS the preferred one!
You might try to prepend your AS number several times when advertising, e.g.
It might be also worth to discuss with the neighbor router admin why they prefer your prefix over the MPLS one.
BR,
Milan
See below topology. 192.168.242.0/24 is Site B addess. So when Site B mpls down i get routes on site A over Backup but when site B mpls up, i still receive route from ospf and is advertise to BGP peer, though it should receive this route from BGP peer.
OSPF domain is backup as i am redisbuting b/w ospf processes and making E2 routes and while over BGP i am making E1 routes.
Apologize for poor drawing,
Well, I'm getting almost lost.
I'd suggest to focus on the question:
Why when the MPLS is Up again, the BGP router on site B is NOT advertising the 192.168.242.0/24 subnet to site A via BGP?
Isn't it because it is receiving the same prefix from site A and takes it as the best BGP prefix?
Can you provide the
sh ip bgp 192.168.242.0/24
output from BGP router on site B at the moment when MPLS is Up again?
BR,
Milan
Now you are correct.. when MPLS site B up again i dont see this route being advertised to BGP peer but what i see this route is being recevied from the peer.
Because site A is still advertising this route to its BGP peer rather being received.
I cannot make this route to stop advertising on site A. I tried to filter(deny) this route on site B to be received from peer but it did not make any change on site A. Site A was still advertising this route to peer(Although it should receive this route from peer)
