Reflexive ACL behaviour
snarayanaraju
Level 4
Level 4
Hi friends,
A basic doubt.
I am checking REFLEXIVE ACLs. During Lab i found this behaviour.
152.50.12.1 (R1)-----(R2) 150.50.7.7
where 150.50.12.1 is untrusted & 150.50.7.7 is trusted.
Reflexive ACLs are configured and working perfectly as expected. When I
initiated ICMP ping from 150.50.7.7 it is creating Reflexive ACL in R2 as
below:
permit icmp host 150.50.12.1 host 150.50.7.7 (10 matches) (time left 76)
I thought after this temperory ACL creation, I should be able to ping from
150.50.12.1 to 150.50.7.7. But it failed to ping even though I am able to
ping 150.50.12.1 from 150.50.7.7
Is this a normal behaviour?
Thanks for valuable answers
sairam
Peter Paluch
Hi Sairam,
It depends on how you set up both the pair of ACLs. Can you post the configuration of the router that contains the reflexive ACL?
Best regards,
Peter
Hi Peter,
Configuration is done on R2
ip access-list TRUSTED-UNTRUSTED
permit ip any any reflect SAIRAM
ip access-list UNTRUSTED-TRUSTED
evaluate SAIRAM
interface ser 0/0
des #### UNTRUSTED #####
ip access-group UNTRUSTED-TRUSTED in
interface fa 0/0
des ##### TRUSTED #####
ip access-group TRUSTED-UNTRUSTED in
Peter, this is the snapshot of the configuration made on R2
Hope this is sufficient to help me
Sairam
Hello Sairam,
Your config is OK. I believe that the reason that it does not work lies in the fact that despite the "show access-list" command shows only the hosts and protocol in your reflexive ACL, internally the reflexive ACL holds more information about how the return packet should look like. I suspect that for ICMP, when you ping from inside to outside, the reflexive ACL will match for an ICMP echo-reply message. This would also explain why pinging from outside to inside does not work: the packets are of the type ICMP echo, not echo-request as the reflexive ACL entry expects.
Maybe you should try testing this with a real equipment and some packet generator that is able to generate a packet from an arbitrary port - the "netcat" utility for Linux can be used for that. I suggest using UDP packets as they have no state information in their header.
Best regards,
Peter
