Community Member
reg:1841 NBR ISsue
Dear experts,
i have cisco 1841 router in that Iam trying block some of the sites using NBR
but i am unable to trace out the problem.
plz go through the config and plz tell me where i was wrong,
sh run
Building configuration...
Current configuration : 1284 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
--More-- ip cef
no ip dhcp use vrf connected
ip name-server 202.71.156.176
ip name-server 202.56.250.6
class-map match-any block-sites
match protocol http url "youtube.com"
match protocol http url "games.com"
policy-map mark-blocked-sites
class block-sites
set ip dscp 1
interface FastEthernet0/0
--More-- ip address 192.168.1.1 255.255.255.0 secondary
ip address 61.8.156.57 255.255.255.248
ip nat inside
duplex auto
speed auto
service-policy input mark-blocked-sites
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
ip address 202.71.159.62 255.255.255.252
ip access-group 101 out
ip nat outside
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
ip http server
ip nat inside source list 1 interface FastEthernet0/0 overload
--More-- !
access-list 1 permit any
access-list 101 deny ip any any dscp 1
access-list 101 permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Router#
Thanks&Regard
srini
1 REPLY
Re: reg:1841 NBR ISsue
can you paste the output of "show policy-map" ?
Also check whether DSCP 1 hit count is increasing or not ??
100
