reg:3550 12t ports r not recognising
Dear sir,
iam having 3550 12t switch in that i loded ios through xmodem loding is successfull.but in mode ststus all lights r glowing .while i reboot the switch in that iam getting this msg:
POST: CPU Interface Tests : End, Status Failed
so iam attaching the boot file plz help in this.
Thanks&Regards
srinivas.D
Re: reg:3550 12t ports r not recognising
Hi Srini
Are you trying to upgrade the ios in your switch ? if yes can you revert back to the old ios if you have backed up a copy of the same.
I suspect low memory issues which prevents loading of the new ios..
SYSTEM INIT: INSUFFICIENT MEMORY(576 BYTES) TO BOOT THE IMAGE!
regds
Dearsir,
thanks for ur reply i gone through flash_init
iam having 16mb flash but its showing not enough space
Initializing Flash...
flashfs[0]: 4 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 16128000
flashfs[0]: Bytes used: 5571072
flashfs[0]: Bytes available: 10556928
flashfs[0]: flashfs fsck took 9 seconds.
...done Initializing Flash.
plz help me what can i do next
srinivas.D
is the system booting realy?
dear sir,
systm is booting iam having enough mem
i gon through flasInitializing Flash...
...done Initializing Flash.h_init:
so plz tell me what can i do next
srinivas.d
115
