Community Member
Reg:cisco router 2800
Dear sir,
We have a head office in hyderabad having 2801 router in that advanced ip services ios is there and we have branch office at bangalore there also we have 2801 router in that we have advanced ip services ios is there already point to point leased line is working now we r planing and we have broad band at both sides now we r planing to implement vpn as backup line .in head office we have 2 sap servers my remote branch people is acceses to this servers.In which way is better (ipsec or ssl)plz give me config examples.
srinivas
Hall of Fame Super Gold
Re: Reg:cisco router 2800
Hi, look for "configuring gre tunnel" in the documentation.
After you got that running, you can encrypt with IPsec, but make the GRE tunnel work first.
Community Member
Dear sir,
thanks for ur reply but i didnt get any example for that.
plz give me the examples.
srini
Hi, you need to become familiar with cisco documentation, you enter "configuring gre tunnels" in the search box and you're presented with many results.
Community Member
Hi,srini
I suggest you using Cisco Easy VPN between HQ and branch, HQ`s 2801 will acts as Easy VPN server, PC in the branch act as VPN Client with Cisco VPN Client software.
so, branch will not need net-admin to maintain the configuration of IPSEC.
all the VPN configuration are on the HQ router.
hope this help
regards
dongdong
127
