Community Member
Reg: Hardware failure
Hi Guys,
What is the command on the router to check if any hardware has failed. For example fan.
Tks
1 REPLY
Hall of Fame Super Gold
Re: Reg: Hardware failure
kuldeep
There are a number of commands that might fit this general description. But I think that you are probably thinking about the show diag command.
Rick
107
