Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Reg:head office to multipoint
Dear sir,
we have head ofiice in hyd with in the hyderabd we have 11 branch officeses through fiber all branch offices r coneected .now head office and all remotes r having l3(3560)switches.now i want link redundancy if one link fails all the trafic has diverted to the other link.how much time wii take for this.
plz give me reply what way is the best.
regards
srini
Re: Reg:head office to multipoint
The question is not very clear. All branches connected by fiber, does it mean its a ring network. R u running any routing protocol? Can u share the diagram.
Dear bvsnarayana,
Thanks for ur mail .yes it was a ring topology.now there is no routing protocols now all the switches r acting as unmangeble switches.now plz suggest me i want to mange all the links as fail over.which protocol is best(spanning tree,trunk like that.)we doesnt have diagram.
plz give me the sample examples.
regards
srini
HI Srini, [Pls Rate if HELPS]
Refer link below for Reliable Static Routing Backup with Object Tracking ==> compatible with Pre-configured static routes as well as with DHCP Configurations.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5413/products_feature_guide09186a00801d862d.html
PLS RATE if HELPS
Best Regards,
Guru Prasad R
113
