Reg:segrigation
Dear sir,
Can i segrigate the banwidth with single leased line from the HO to multiple BO.Using 3560 switch or any possibility on 1841 router.
srinivas
1 REPLY
Hall of Fame Super Gold
Re: Reg:segrigation
Yes. Use a router for this task. Under the serial interface, configure a service-policy.
Then you will have class-map that will define QoS for different BO using ACLs.
The specifics depends on what exactly you want to do, if you have voice, etc.
82
