06-06-2008 11:56 PM - edited 03-03-2019 10:16 PM
Dear sir,
We have a point to multipoint leased lines and alredy established and working fine but i configured eigrp on the routers but the switching time for link to link is vry high .we want the switching time less than 5 seconds.
Iam attaching my existing config plz tell me how can i achive the target.
Thanks&Regar
srini
06-07-2008 12:56 AM
You can manipulate the EIGRP hello and hold timers on the links that you have.
I my environment we send hello's ever second - the hold time is 3 seconds. So if the neighbour does not receive a hello after 3 seconds that neighbour is dead, and the feasible sucessor takes over.
You can amned the timers lower - howwever I would not recommend this, as you could introduce flapping links.
HTH.
06-07-2008 01:06 AM
Dear sir,
Thanks for ur reply and is there any document for maniplating EIGRP hello.
srini
06-07-2008 01:14 AM
The commands are place in the interface:-
ip hello-interval eigrp
example:- ip hello-interval eigrp 3 1
ip hold-time eigrp
example:- ip hold-time eigrp 3 3
