regarding cisco 2821 NM module
Hi ,
         I have 2821 router and i have 4 HWIC cards , 1 for voice module . Now i need a NM which should have atleast 4 ports . I tried to find the information on cisco but not given in detail . Plz provide me NM model number and sopport on 2821 for atleast 2 mbps for each port.
Thanks and regards,
Taran
Hall of Fame Super Gold
Re: regarding cisco 2821 NM module
"Ports" of which type ???
             My requirement is to connect with lease lines . It may be with serial ports or may be e1 with rj45 connectivity.
thanks
Taran
What type exactly you need ?
            Actually I need a module for serial port. The connectivity can be with v.35 cable or it can be with e1 ports. The main goal is to connect lease lines.
thanks
Taran
Cisco makes both, so you have to decide, one or the other.
E1 ports .
Then you must free HWIC slots, or add another router.
1.     The Cisco 2811 does not support the HWIC-4T1/E1 module
2.     The 4-port clear channel HWIC supports 1 channel per port, or 4 channels total for the HWIC.
NM-CEM-4TE1 : Four-port Channelized,Unchannelized E1/T1 Network Module
NM-CEM-4SER : Four-port Channelized,Unchannelized E1/T1 Network Module
Shailesh I think you are right . Even I found that only this card is compatible with 2821 NM . What u say should go for it if I need atleast 4 port card ?
thanks
Taran
Yes, you may select one of two cards suits to you
Please rate this response if information provided useful to u
With regards,
Shailesh
Incorrect, these are Circuit Emulation Module, NOT apt for regular WAN circuits.
HI
          I have checked that the module you mentioned not supported on 2821 router . I cheked this on cisco's documentation. So if these two CEM are not useful then what u say which module should   I choose ?
Taran
            http://www.cisco.com/en/US/prod/collateral/routers/ps5854/prod_qas0900aecd80169bd6.html
It shows that NM-8CE1T1-PRI not sopported on 2821 router .
thanks
Taran
         But these modules are not supported on 2800 router . As I told u my requirement is for only 2821 router.
Taran
HI
             thanks for instant reply. I respect ur feedback but the first link u send me , see the table 3 . it shows that this module has N/A for 2821 router . I am bit confused what should I choose ??
Taran
4-port asynchronous/synchronous serial network module ; Part no. NM-4A/S referring to following link. But this not support beyond 128 Kbps
. It support to both synchronous and anysynchronous communication
http://www.cisco.com/en/US/partner/docs/routers/access/interfaces/nm/hardware/installation/guide/OvrNetM.html
>>> NM-4T does not support to 2821 router
>> NM-CEM-4SER is Four-port Channelized,Unchannelized E1/T1Network Module (Provides four Smart Serial
(Cisco 12-in-1) ports for bit-transparent transport services. Each port may be V.35, X.21, RS-422/449,
RS-530, RS-530A, or RS-232. Each port may be DCE or DTE supporting data rates from 200 bps to 2048 Kbps.)
>> NM-CEM-4TE1 - Four-port Channelized, Unchannelized E1/T1 Network Module Provides four RJ-45
channelized/unchannelized, framed/unframed T1/E1 ports forbit-transparent transport services.
Information about circuit emulation - http://www.cisco.com/en/US/partner/products/hw/routers/ps274/products_qanda_item09186a0080204358.shtml
I think NM-CEM-4SER more suitable to you..
You are correct. I have edited my replies above, and apologize for the confusion.
          Now it seems to me that our discussion going to a very interesting way. So according to both of you what should be the right choice ? I am still not able to decide and its urgent for me .
Thanks and regards,
Taran
Send "show diag".
Slot 0:
        C2821 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
        Port adapter is analyzed
        Port adapter insertion time unknown
        Onboard VPN             : v2.2.0
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC10521UTR
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-26921-02
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 03
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 87
        Hardware date code       : 20061228
        Chassis Serial Number    : FHK1102F0M6
        Chassis MAC Address      : 001a.a1df.3d30
        MAC Address block size   : 32
        CLEI Code                : COM3D00BRA
        Product (FRU) Number     : CISCO2821
        Part Number              : 73-8853-04
        Version Identifier       : V03
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 30 35 32 31 55 54 52 40
          0x10: 03 E8 41 01 00 C0 46 03 20 00 69 29 02 42 41 30
          0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00
          0x30: 09 87 83 01 32 1C 2C C2 8B 46 48 4B 31 31 30 32
          0x40: 46 30 4D 36 C3 06 00 1A A1 DF 3D 30 43 00 20 C6
          0x50: 8A 43 4F 4D 33 44 30 30 42 52 41 CB 8F 43 49 53
          0x60: 43 4F 32 38 32 31 20 20 20 20 20 20 82 49 22 95
          0x70: 04 89 56 30 33 20 D9 02 40 C1 FF FF FF FF FF FF
        WIC Slot 0:
        4 Port FE Switch
        Base MAC Address         : 0019.304f.70ac
        MAC Address block size   : 4
        PCB Serial Number        : FOC110142V3
        Hardware Revision        : 6.0
        Part Number              : 73-8474-06
        Board Revision           : A0
        Top Assy. Part Number    : 800-24193-02
        Fab Version              : 05
        CLEI Code                : IPUIA00RAA
        RMA History              : 00
        Product (FRU) Number     : HWIC-4ESW
        Version Identifier       : V01
        Connector Type           : 01
          0x00: 04 FF CF 06 00 19 30 4F 70 AC 43 00 04 C1 8B 46
          0x10: 4F 43 31 31 30 31 34 32 56 33 40 00 56 41 06 00
          0x20: 82 49 21 1A 06 42 41 30 C0 46 03 20 00 5E 81 02
          0x30: 88 00 00 00 00 02 05 C6 8A 49 50 55 49 41 30 30
          0x40: 52 41 41 03 00 81 00 00 00 00 04 00 CB 89 48 57
          0x50: 49 43 2D 34 45 53 57 89 56 30 31 20 D9 02 C1 40
          0x60: 05 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 1:
        VWIC2-1MFT-G703 - 1-Port RJ-48 Multiflex Trunk - T1/E1 & G.703
        Hardware Revision        : 0.0
        Top Assy. Part Number    : 800-24918-05
        Board Revision           : A0
        Fab Version              : 04
        PCB Serial Number        : FOC10482SX6
        RMA History              : 00
        Product (FRU) Number     : VWIC2-1MFT-G703
          0x00: 04 FF 40 03 FA 41 00 00 C0 46 03 20 00 61 56 05
          0x10: 42 41 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 30 34 38 32 53 58 36 03 00 81 00 00 00 00 04 00
          0x30: CB 8F 56 57 49 43 32 2D 31 4D 46 54 2D 47 37 30
          0x40: 33 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 2:
        VWIC2-2MFT-G703 - 2-Port RJ-48 Multiflex Trunk - T1/E1 & G.703
        Top Assy. Part Number    : 800-24920-05
        Board Revision           : A0
        Fab Version              : 04
        PCB Serial Number        : FOC10506E26
        RMA History              : 00
        Product (FRU) Number     : VWIC2-2MFT-G703
          0x00: 04 FF 40 03 FB 41 00 00 C0 46 03 20 00 61 58 05
          0x20: 30 35 30 36 45 32 36 03 00 81 00 00 00 00 04 00
          0x30: CB 8F 56 57 49 43 32 2D 32 4D 46 54 2D 47 37 30
AIM Module in slot: 0
        PCB Serial Number        : FOC10522RY6
        Hardware Revision        : 1.1
        Top Assy. Part Number    : 800-24799-02
        Board Revision           : A0
        Fab Version              : 03
        RMA History              : 00
        CLEI Code                : CNUIAEEAAA
        Product (FRU) Number     : AIM-VPN/EPII-PLUS
          0x00: 04 FF C1 8B 46 4F 43 31 30 35 32 32 52 59 36 40
          0x10: 01 4B 41 01 01 C0 46 03 20 00 60 DF 02 42 41 30
          0x30: C6 8A 43 4E 55 49 41 45 45 41 41 41 CB 91 41 49
          0x40: 4D 2D 56 50 4E 2F 45 50 49 49 2D 50 4C 55 53 89
          0x50: 56 30 31 20 FF FF FF FF FF FF FF FF FF FF FF FF
There is an emply slot, but I suppose you will need it for some other purpose
You can replace HWIC-4FE, then use HWIC-4T1/E1
If used for data, you can also replace the 2 VWIC with one HWIC-4T1/E1.
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/product_data_sheet0900aecd80710c77.html
Thanks for reply. Actually I also considered this HWIC already but the thing is due to my requirement I have to get one more module for some other connections and I found everywhere but no results for this module .
thanks
Taran
It's very interesting... indeed.. will keep digging something...Do you have anything specific in mind so far?
HI
             I am also thinking about CEM . Dont know exactly what to do . Actually I have searched a lot about it and even talked to lot of frnds but didnt get results. I hope we will find something about it .
Taran
As mentioned above, since you have no need for CEM, these products are now right for you.
Beside, they are very espensive.
You only have to replace the VWIC for HWIC as indicated above.
Incorrecte, the OP does not need to do CEM, consequently CEM modules are NOT suiltable.
1187
