09-30-2007 03:08 AM - edited 03-03-2019 06:57 PM
Can somebody help me what is S1841PB-12411XJ IOS ????? How can i see whether i have that IOS or not ???
I tried
sh ver
sh diag
sh platform
dir flash:
almost everything I knew but I couldnt get that. Can i get the exact keyword S1841PB-12411XJ while typing some commmand.
The issue is we had ordered a 1841 router , the vendor has listed
S1841PB-12411XJ - 1 No.
I couldnt understand this.
Help !!!!!!!
Solved! Go to Solution.
09-30-2007 05:52 AM
show ver is the one.
I *suspect* there may be a typo in there. Add an "I" and you get the order code for IP Base. Note the order code is *NOT* the filename.
The order code is S184IPB-12411XJ
I can normally work back from the file name to IOS, but the other way is more challenging. Post the output of a she ver and I can confirm hat you have. I would expect the filename the image is loaded from to look something like c1841-ipbase-mz.124-11.XJ.bin for that particular version.
That is early deployment software. Unless you have some urgent need for sothig supported only in that software I would not recommend you use it. I would suggest something like IP Base 12.4.17 that should be more stable.
Paul.
09-30-2007 05:15 AM
The code you referenced does not appear to be a cisco code. So you will never see it in show commands.
09-30-2007 05:52 AM
Paul.
09-30-2007 09:28 PM
Thanks Paul,
My IOS is the stable one IP BASE 12.4.17. Thanks a lot.
Bsnta
09-30-2007 11:39 PM
You are welcome.
P.
