I need to send all my voip traffic using a single ISP router (bgp peer). We'll be load balancing to 4 peers on the same AS.
Connection are done via fastethernet, our core 4506 connects to a layer 2 device and then to the ISP peers (all ethernet).
My first suggestion would be PBR with object tracking, but this is not supported on the 4506.
Is there a way to make this policy routing reliable?
As "set ip next-hop IP1 IP2" wouldnt be that effective, as the interface would need to go down before trying a different IP.
Please let me know,
Vlad
