Community Member
Reload manual or power off on router
Dear,
We have router which is up since 2 days and I would like to know if the router has reloaded by CLI (Reload) or by power off(Electrical problem)
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-KBOOT-M), Version 12.4(4)XD9, RELEASE SOFTWARE (fc1)
Router-Test-01 uptime is 2 days, 21 hours, 0 minutes
System returned to ROM by reload at 16:54:56 UTC Mon Feb 9 2009
System restarted at 16:56:23 UTC Mon Feb 9 2009
Last reload reason: Reload Command
Last reset from power-on
1 FastEthernet interface
4 Gigabit Ethernet interfaces
2045K bytes of NVRAM.
Re: Reload manual or power off on router
it was manuall reloaded from the cli.
Community Member
How you can say it?
This statement indicates it...
Last reload reason: Reload Command.
If it helps, please rate post..
Community Member
Thanks, I rate it
Bronze
Because the output says
"System returned to ROM by reload at 16:54:56 UTC Mon Feb 9 2009"
If it was a power problem it would have said something like
"System returned to ROM by unknown reload cause"
Hall of Fame Super Gold
They're all right. The second and the last line always gives you a clue.
If it's a power outage, the line would go something like "System returned to ROM by power-on".
If there was something wrong, in this case a system crash, you'd get an alarm like this:
System returned to ROM by error - Software Forced Crash Exception (0x0700)!, PC 0x3ED134
System restarted at 05:10:29 AEDST Tue Nov 18 2008
If it was reloaded, you still get this
System returned to ROM by reload at 15:55:01 AEDST Fri Feb 6 2009
Does this help?
478
