Webcast-Catalyst9k
reloading module
Our second sup is continously reloading. Please advise...
*Apr 24 12:37:03.387: %OIR-SP-3-PWRCYCLE: Card in module 6, is being power-cycled (Module reset)
*Apr 24 12:38:55.614: %PFREDUN-SP-6-ACTIVE: Standby initializing for SSO mode
*Apr 24 12:39:11.707: %CHKPT-SP-4-GET_HUGE_BUF: Client 163 buffer requested (size = 6160) is too large
*Apr 24 12:39:28.374: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 6.
*Apr 24 12:39:53.450: %ONLINE-SP-6-INITFAIL: Module 6: Failed to synchronize Port asic
*Apr 24 12:40:04.026: %PFREDUN-SP-6-ACTIVE: Standby processor removed or reloaded, changing to Simplex mode
*Apr 24 12:40:04.026: %OIR-SP-3-PWRCYCLE: Card in module 6, is being power-cycled (Module reset)
*Apr 24 12:41:56.381: %PFREDUN-SP-6-ACTIVE: Standby initializing for SSO mode
*Apr 24 12:42:12.030: %CHKPT-SP-4-GET_HUGE_BUF: Client 163 buffer requested (size = 6160) is too large
*Apr 24 12:42:28.705: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 6.
*Apr 24 12:42:54.111: %ONLINE-SP-6-INITFAIL: Module 6: Failed to synchronize Port asic
*Apr 24 12:43:04.807: %PFREDUN-SP-6-ACTIVE: Standby processor removed or reloaded, changing to Simplex mode
*Apr 24 12:43:04.807: %OIR-SP-3-PWRCYCLE: Card in module 6, is being power-cycled (Module reset)
*Apr 24 12:44:57.040: %PFREDUN-SP-6-ACTIVE: Standby initializing for SSO mode
*Apr 24 12:45:13.219: %CHKPT-SP-4-GET_HUGE_BUF: Client 163 buffer requested (size = 6160) is too large
*Apr 24 12:45:29.948: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 6.
*Apr 24 12:45:55.230: %ONLINE-SP-6-INITFAIL: Module 6: Failed to synchronize Port asic
*Apr 24 12:46:05.955: %PFREDUN-SP-6-ACTIVE: Standby processor removed or reloaded, changing to Simplex mode
*Apr 24 12:46:05.955: %OIR-SP-3-PWRCYCLE: Card in module 6, is being power-cycled (Module reset)
*Apr 24 12:47:58.168: %PFREDUN-SP-6-ACTIVE: Standby initializing for SSO mode
*Apr 24 12:48:13.442: %CHKPT-SP-4-GET_HUGE_BUF: Client 163 buffer requested (size = 6160) is too large
*Apr 24 12:48:30.212: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 6.
*Apr 24 12:48:55.418: %ONLINE-SP-6-INITFAIL: Module 6: Failed to synchronize Port asic
*Apr 24 12:49:06.418: %PFREDUN-SP-6-ACTIVE: Standby processor removed or reloaded, changing to Simplex mode
*Apr 24 12:49:06.418: %OIR-SP-3-PWRCYCLE: Card in module 6, is being power-cycled (Module reset)
*Apr 24 12:50:58.319: %PFREDUN-SP-6-ACTIVE: Standby initializing for SSO mode
*Apr 24 12:51:13.694: %CHKPT-SP-4-GET_HUGE_BUF: Client 163 buffer requested (size = 6160) is too large
*Apr 24 12:51:30.407: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 6.
*Apr 24 12:51:55.636: %ONLINE-SP-6-INITFAIL: Module 6: Failed to synchronize Port asic
*Apr 24 12:52:06.433: %PFREDUN-SP-6-ACTIVE: Standby processor removed or reloaded, changing to Simplex mode
[13:58:10] : *Apr 24 12:52:06.433: %OIR-SP-3-PWRCYCLE: Card in module 6, is being power-cycled (Module reset)
*Apr 24 12:53:58.570: %PFREDUN-SP-6-ACTIVE: Standby initializing for SSO mode
*Apr 24 12:54:13.948: %CHKPT-SP-4-GET_HUGE_BUF: Client 163 buffer requested (size = 6160) is too large
*Apr 24 12:54:30.594: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 6.
*Apr 24 12:54:55.758: %ONLINE-SP-6-INITFAIL: Module 6: Failed to synchronize Port asic
*Apr 24 12:55:06.198: %PFREDUN-SP-6-ACTIVE: Standby processor removed or reloaded, changing to Simplex mode
*Apr 24 12:55:06.198: %OIR-SP-3-PWRCYCLE: Card in module 6, is being power-cycled (Module reset)
*Apr 24 12:56:58.749: %PFREDUN-SP-6-ACTIVE: Standby initializing for SSO mode
*Apr 24 12:57:14.243: %CHKPT-SP-4-GET_HUGE_BUF: Client 163 buffer requested (size = 6160) is too large
*Apr 24 12:57:30.963: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 6.
*Apr 24 12:57:56.023: %ONLINE-SP-6-INITFAIL: Module 6: Failed to synchronize Port asic
*Apr 24 12:58:06.126: %PFREDUN-SP-6-ACTIVE: Standby processor removed or reloaded, changing to Simplex mode
[13:58:18] : *Apr 24 12:58:06.126: %OIR-SP-3-PWRCYCLE: Card in module 6, is being power-cycled (Module reset)
*Apr 24 12:59:58.954: %PFREDUN-SP-6-ACTIVE: Standby initializing for SSO mode
*Apr 24 13:00:14.410: %CHKPT-SP-4-GET_HUGE_BUF: Client 163 buffer requested (size = 6160) is too large
Re: reloading module
Muhammed,
The error %CHKPT-SP-4-GET_HUGE_BUF looks like it could be a bug that's harmless:
https://supportforums.cisco.com/thread/346330
Aside from that, I would open a TAC case to see if you have a problem with the SUP. What version of IOS are you running?
John
HTH, John *** Please rate all useful posts ***
Hi Muhammed,
Try to reset the module & check for bad contact or badly seated card.
Palaniswamy
1101
