Community Member
remote access VPN cant ping but not remote desktop
I have setup remote access IP sec VPN in my 881.
Here is the config:
Building configuration...
Current configuration : 3402 bytes
! Last configuration change at 08:38:46 UTC Tue May 27 2014 by akshay
version 15.2
no service pad
service password-encryption
hostname TheSagarRouter
boot-start-marker
boot-end-marker
enable secret 4 8sb95.4HVhofmKquQwxZLr468VgrsA5qWpNigAEDtf2
aaa new-model
aaa authentication login VPN_CLIENT_LOGIN local
aaa authorization network VPN_CLIENT_GROUP local
aaa session-id common
memory-size iomem 10
ip dhcp excluded-address 192.168.10.1
ip dhcp pool VLAN_10_ARCHITECTURE
 network 192.168.10.0 255.255.255.0
 default-router 192.168.10.1
 dns-server 8.8.8.8
ip domain name thesagar.in
ip name-server 8.8.8.8
ip cef
no ipv6 cef
license udi pid CISCO881-K9 sn FGL171220ER
username akshay privilege 15 secret 4 cI9fbmTlloLTKDmg0s6Pctre4U2C74KpINniT7DII2M
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
crypto isakmp policy 10
 encr 3des
 authentication pre-share
 group 2
 lifetime 3600
crypto isakmp client configuration group VPN_CLIENTS
 key ClientVpnKey
 dns 8.8.8.8
 domain thesagar.in
 pool VPN_CLIENT_POOL
 acl 110
crypto ipsec transform-set TRANS_3DES_SHA esp-3des esp-sha-hmac
 mode tunnel
crypto ipsec df-bit clear
crypto dynamic-map EXT_DYNAMIC_MAP 10
 set transform-set TRANS_3DES_SHA
crypto map EXT_MAP client authentication list VPN_CLIENT_LOGIN
crypto map EXT_MAP isakmp authorization list VPN_CLIENT_GROUP
crypto map EXT_MAP client configuration address respond
crypto map EXT_MAP 10 ipsec-isakmp dynamic EXT_DYNAMIC_MAP
interface FastEthernet0
 switchport access vlan 10
 switchport mode trunk
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 ip address 182.74.72.98 255.255.255.252
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 crypto map EXT_MAP
interface Vlan1
 ip nat inside
interface Vlan10
 ip address 192.168.10.1 255.255.255.0
 ip nat inside
ip local pool VPN_CLIENT_POOL 192.168.20.200 192.168.20.210
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list NATTABLE_HOSTS interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 182.74.72.97
ip access-list extended NATTABLE_HOSTS
 deny   ip 192.168.1.0 0.0.0.255 192.168.20.0 0.0.0.255
 deny   ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
 permit ip any any
access-list 110 permit ip 192.168.1.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 110 permit ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
banner motd ^C
This is a secured router. Logging in to it is not allowed.
^C
line con 0
 exec-timeout 5 0
 logging synchronous
 no modem enable
line aux 0
line vty 0 4
 exec-timeout 0 0
 logging synchronous
 transport input telnet ssh
end
I have one machine at 192.168.10.8, which I can ping to but cant do remote desktop. Any help would be appreciated.
109
