remote access
hi guys,
from the central station I can ping the Async port of my remote router but i can not ping the fastethernet interface!!
any solution?
Hall of Fame Super Silver
Re: remote access
ehsan
There might be several things that could cause the symptoms that you describe.
- the central station might have a route to the address of the Async port but not have a route to the FastEthernet.
- there might be an access list that permits ping to some addresses but not to other addresses.
- is there some possibility that the remote FastEthernet might not be up/up?
- there might be issues on the remote controlling what traffic is sent over the async interface.
If you provide details like the configuration of the router we would be better able to help you.
Rick
Re: remote access
Dear rick thank you for your attention:
here is the configure for 2800
version 12.4
hostname 2800
boot-start-marker
boot-end-marker
enable secret xxx
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip domain lookup
chat-script Dialout ABORT ERROR ABORT BUSY ABORT "NO ANSWER" "" "AT" OK "ATDT\T" TIMEOUT 40 CONNECT \c
modemcap entry pooria
username xxx password xxx
interface FastEthernet0/0
ip address 172.20.1.4 255.255.255.128
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface Async1/0
no ip address
encapsulation ppp
no ip route-cache cef
dialer in-band
dialer pool-member 1
dialer-group 1
async dynamic routing
async mode dedicated
routing dynamic
interface Dialer1
ip address 192.168.0.1 255.255.255.252
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer idle-timeout 0
dialer fast-idle 180
dialer string Dilaout
dialer string 44843763 modem-script dialout
dialer-group 1
ppp authentication chap
router eigrp 7
network 172.20.1.0 0.0.0.127
network 192.168.0.0 0.0.0.3
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 172.20.1.1
ip route 172.25.150.0 255.255.255.252 192.168.0.2
ip http server
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line 1/0 1/15
exec-timeout 0 0
no flush-at-activation
script dialer Dialout
modem InOut
modem autoconfigure discovery
transport input all
transport output all
stopbits 1
flowcontrol hardware
line vty 0 4
login local
scheduler allocate 20000 1000
end
here is also the configure of Async router
version 12.4
no service pad
service password-encryption
hostname 871
boot-start-marker
boot-end-marker
enable secret xxx
enable password xxx
aaa new-model
aaa authentication login default local
aaa authentication login no_login none
aaa authentication ppp default local none
aaa session-id common
resource policy
ip cef
no ip domain lookup
modemcap entry POL:MSC=&F1S0=1
username cisco password xxx
username 2800 password xxx
interface Loopback0
ip address 172.25.150.1 255.255.255.252
shutdown
interface FastEthernet1
shutdown
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface FastEthernet4
no ip address
duplex auto
speed auto
interface Vlan1
no ip address
interface Async1
ip address 192.168.0.2 255.255.255.252
encapsulation ppp
dialer in-band
async mode interactive
peer default ip address 192.168.0.1
routing dynamic
ip route 0.0.0.0 0.0.0.0 192.168.0.1
no ip http server
no ip http secure-server
control-plane
line con 0
modem autoconfigure type POL
modem enable
speed 115200
line aux 0
exec-timeout 0 0
login authentication no_login
modem InOut
autocommand ppp default
transport input all
stopbits 1
speed 115200
line vty 0 4
transport input all
scheduler max-task-time 5000
webvpn context Default_context
ssl authenticate verify all
no inservice
end
Re: remote access
ehsan
Thanks for posting the router configs. They are quite helpful in understanding your problem. Your origional post indicates that you can not ping the remote FastEthernet. The config shows that there are 5 FastEthernet interfaces and 4 of them are shutdown and the last one has no IP address. You certainly can not ping an interface that is shut down nor an interface that has no IP address.
shutdown
shutdown
shutdown
shutdown
no ip address
duplex auto
speed auto
Rick
200
