remote branch design...
From a design point of view, would it be best to the switch operate as layer 3? I want the switch to share the load with the router. The site usually has 50 concurrent connections.
What would be best option?
Many thanks
1 REPLY
Hall of Fame Super Silver
Re: remote branch design...
With a branch size of about 50 I think it will not make a significant difference. The diagram shows 2 access layer switches connected to a single distribution layer switch. In that situation I believe that it is best if the distribution switch is a layer 3 switch and is doing routing for inter vlan communication. In this way the layer 3 switch carries responsibility for routing within the branch and the router is able to focus on routing for outside of the branch.
Rick
149
