Community Member
Replace cisco router 3825 for 2921
Hi all
I have a cisco router 3825 running over 100% full time and I am planning to replace it for cisco router 2921 but I am not sure if cisco 2921 is good enough to replace 3825, however 2921 is the only router I have available to replace it.
Any helps it is comming in a good time
Super Bronze
DisclaimerThe Author of this
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
The 3825 is rated at 350 Kpps, the 2921 is rated at 480 Kpps, so its CPU is about 37% faster.
Whether that will be sufficient for your need, cannot say.
Community Member
Thank you very much
Thank you very much
