Webcast-Catalyst9k
Require help in NTP Config
Can somebody tell me how to configure NTP.Which router i can configure as a NTP server for sync with cleint.
Pls brief me the config on both ntp server and cleint.
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: Require help in NTP Config
Cisco routers aren't the ideal NTP servers. I suggest syncing your routers against a reliable internet NTP server. For more information on NTP, please refer to the documentation:
http://www.cisco.com/en/US/docs/ios/netmgmt/configuration/guide/nm_basic_sys_manage_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1001170
HTH,
__
Edison.
HTH,
__
Edison.
Hall of Fame Super Gold
Edison's right. Synchronise your router(s) with a authorized time server based on your geographical location. If you are in England, don't synchronize with a time server in China, for example.
A list of the Simple Network Time Protocol (SNTP) time servers that are available on the Internet
http://support.microsoft.com/kb/262680
Leo,
I wouldn't recommend polling time from SNTP servers (slightly different protocol).
Here is a list from Public NTP Servers:
http://support.ntp.org/bin/view/Servers/WebHome
Whoopsie. True. But you can use the same (S)NTP servers as NTP.
164
