reverse telnet break
cnrs-dsi
We have a 2821 with 16 asynchronous lines to connect to switch and routers console ports.
We connect first to the 2821 router and then to final switch or router.
Problem :
When we are connected to the final router, we can't go back to the 2821.
We have tried many combinaisons ctrl+shif+6 x and many others.
The only that work is to send a "telnet break" when we are connected to a switch.
(KO with routers grrrrrr)
2821 config
line 0/1/0 0/1/15
exec-timeout 0 0
modem InOut hangup
no exec
transport input all
transport output all
telnet break-on-ip
telnet sync-on-break
telnet ip-on-break
switch config (2924 works with telnet break)
line con 0
exec-timeout 0 0
transport input none
stopbits 1
router config (3640 telnet break doesn't work)
line con 0
exec-timeout 0 0
transport preferred none
stopbits 1
We tried with Putty teraterm crt..
If you have any idea.
Giuseppe Larosa
Hello joel,
I do the following:
open another telnet session to terminal server C2821
issue a sh line vty
find what line is used by reverse-telnet
clear line vty
In this way I can free the line vty used by reverse telnet
Hope to help
Giuseppe
Giuseppe Larosa
Hello joel,
I do the following:
issue a sh line vty
clear line vty
Hope to help
Giuseppe
Not comfortable but very effective
thank you very much
