Community Member
Reverse Telnet help
Trying to establish a reverse telnet session from my Cisco 2620 router's AUX port to a Cisco 2911 Console port.  Each time I try to get the connection to my loopback address I get a response saying "Connection to closed by foreign host".  I've gone through tons of knowledge articles and believe I have everything set up correctly unless I'm just missing something easy.  Using a flat Cisco roll over cable between the two connections.
2620 Loopback IP:
2620 Aux port configuration:
line aux 0
exec-timeout 0 0
password 7 14141B180F0B
modem InOut
no activation-character
no exec
transport preferred none
transport input all
transport output all
stopbits 1
   Tty Typ     Tx/Rx    A Modem  Roty AccO AccI   Uses   Noise  Overruns   Int
     0 CTY              -    -      -    -    -      0       0     0/0       -
    65 AUX   9600/9600  - inout     -         -         -      0       0       4452/9572    -
2620-rtr01#clear line aux 0
Reverse Telnet help
Reverse Telnet help
2620-rtr01#clear line 65
2620-rtr01#telnet 2065
Trying, 2065 ... Open [Connection to closed by foreign host]  I figure it'll just be a simple config change to get it going but I'm at a loss.  Any help is extremely appreciated!!
