Community Member
RIP Configs
Dear Friendzs,
I am configuring RIP on a L3 Switch cisco 4507. But only taking "IP supernet pool" under network command. I have to advertised two pool in RIP which are as:-
10.10.100.200 255.255.255.248
10.10.100.208 255.255.255.252
Command are given as :-
Router Rip
version 2
network 10.10.100.200
network 10.10.100.208
After executing above commands, while cheking on "Sh Run" output.It reflecting like --->
Router Rip
version 2
network 10.0.0.0
Please check and correct where i am wrong in configuration.
Re: RIP Configs
Disable auto-summary:
router rip
no auto-summary
HTH,
John
HTH, John *** Please rate all useful posts ***
Community Member
Re: RIP Configs
Hii John,
I have done what u suggested, still showing the same output.
router rip
version 2
network 10.0.0.0
no auto-summary
Hall of Fame Super Silver
Re: RIP Configs
Hello Jimmy,
as Joseph has noted RIP converts network commands to major network boundary.
This happens for both RIPv1 and RIPv2.
If it is your desire to have RIPv2 running only on selected interfaces of major network 10/8 you need to use the passive-interface command.
It is the only tool left to you.
if there are many interfaces to be left passive you can use
router rip
passive-interface default
no passive-interface intf1
no passive-interface intf2
see
http://www.cisco.com/en/US/docs/ios/iproute/configuration/guide/irp_ip_prot_indep_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1056595
Be aware that because RIPv2 still misses neighbor state concept your router can hear RIP routes on passive interfaces.
To avoid this the only tool for RIPV2 is a mismatching authentication configuration so that these updates are not accepted.
see
http://www.cisco.com/en/US/docs/ios/iproute/configuration/guide/irp_cfg_info_prot_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1055128
OSPF and EIGRP allows to specify a wildcard mask to mean only subsets of major networks should be running.
Hope to help
Giuseppe
Community Member
Re: RIP Configs
HI Giuseppe,
No, this is not necessary to run rip v2. only looking for as requested, i.e on output only given subneteed will reflect.
regards
Super Bronze
Re: RIP Configs
Some while back, while doing some RIPv2 testing, I recall I discovered the same, i.e. Cisco RIPv2 converts "router RIP" configured network statement addresses to their classful boundaries. It's been a while, so I don't recall all the details, but don't believe I found a work around, and also believe results weren't tied to usage of auto-summary or not (which I think dealt with what RIP advertized).
I do recall I was disappointed that RIPv2 didn't work more like OSPF/EIGRP, although it could do a bit more than RIPv1. For instance, you can deal with discontinous subnets, but also recall I had to play with different classful subnets on transit links to advertize just some intended summaries.
Perhaps someone with extensive Cisco RIPv2 could add to this discussion.
Re: RIP Configs
I completely misread your question yesterday when I answered you. You're seeing "network 10.0.0.0" under the running config for your 10.x.x.x networks, and like the others said, that's normal.
I thought you were being summarized in your routing table and you weren't seeing your specific networks which is what auto-summary would fix. With auto-summary, you would see something like:
R 10.0.0.0/8 via
But with auto-summary turned off you would see something like:
10.0.0.0/24 is subnetted
R 10.15.15.0 via
Sorry for the confusion. Also, if RIP isn't a requirement, I would suggest going with OSPF or EIGRP. If you have equipment other than Cisco, OSPF would be your best bet since it's a standard. If you have ALL Cisco equipment, then you can use EIGRP (Cisco proprietary).
HTH,
John
185
