RIP error
I am trying to configure RIP V2 between 2 Routers. It is working fine.
But in debug message iam getting the error
" RIP: ignored v2 packet from 192.168.2.1 (sourced from one of our address)"
The Router configuration is below:
interface eth 1/0
ip add 192.168.1.0 255.255.255.0
interface eth 1/1
ip add 192.168.2.1 255.255.255.0
router rip
net 0.0.0.0
version 2
What is this message indicate? Can anybody give me a clue to know about this
R.B.Kumar
Re: RIP error
This message purpose is to indicate that one of our own updates has been sent back to us somehow. You would normally see that on the loopback interface if you do not run it as passive. How do you interconnect these two routers?
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Re: RIP error
Hi hritter,
Thanks for your update.
I interconnect these routers using fastethernet.
It seems you are refering about split horizon. I believe that split horizon is enabled in distance vector protocols like RIP. I am correct?
Then why do this message appearing?
Please guide me
R.B.Kumar
Re: RIP error
R.B.Kumar,
I am not referring to split horizon. I think the other poster did. This is not related to split horizon (or the lack of) anyway as we are receiving the RIP update that we formatted ourselves with our own source address. Split horizon would prevent the neighbor from advertising to us the update it has received from us on the same interface.
Do you have a switch between the two routers of just a back to back cable? What is the router at the other end? Could you please provide the full configuration for both routers.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Re: RIP error
R.B.Kumar,
Just to confirm whether there is a loop on the FastE interface, could you please post a "sh cdp nei ".
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Re: RIP error
This is due to split horizon.
- Split horizon is a method of preventing a routing loop in a network. The basic principle is simple: Information about the routing for a particular packet is never sent back in the direction from which it was received.
Re: RIP error
hai,
i think this is not by splithorizon. you just check the ip add of your neighbour.if the neighbour add is in a different net it will happen.
Hall of Fame Super Silver
Re: RIP error
Hello R.B. Kumar,
if there is a lan switch in the middle and if you put both FE on two ports on the same vlan, they can listen to each other hellos and you get this kind of message
Hope to help
Giuseppe
Re: RIP error
could be 2 possiblity
1 is spilithorizon
anoter is thay might have connected in the same lan
and it is sourcifn from the lan
201
