Community Member
RIP updates do not appear in the RIP Database
I've enabled RIP on a vlan segment. I am receiving RIP updates from 3 routers on the segment as verified with "debug ip rip" but the updates from 1 of the routers never make it into the RIP database. Updates from the other 2 routers do make it into the DB. I do not have any filters set in rip (yet...)
Any reason why this would be happening, and how can I resolve it.
Silver
Re: RIP updates do not appear in the RIP Database
do you have a split horizon senario?
Hall of Fame Super Silver
Hello Anthony,
are the updates sent by the third router the same as the other two but with an higher metric (hop count)
Hope to help
Giuseppe
Hall of Fame Super Gold
Anthony
If the good suggestion from Giuseppe is not the solution, then it would be helpful if you would post the debug rip output so that we can see some of the details of what is advertised and accepted and what is advertised but not accepted.
Rick
Community Member
Here is the debug ip rip output. The updates received on vlan 50 are being entered into the RIP database, but the updates received on vlan 110 are not being entered into the RIP Database. I am only sending updates on vlan110
26w4d: RIP: received v2 update from 10.10.10.11 on Vlan110
26w4d: 172.20.1.0/24 via 0.0.0.0 in 1 hops
26w4d: 208.224.251.0/24 via 0.0.0.0 in 1 hops
26w4d: 209.208.175.0/24 via 0.0.0.0 in 1 hops
26w4d: RIP: received v2 update from 10.50.0.15 on Vlan50
26w4d: 69.184.0.0/26 via 0.0.0.0 in 5 hops
26w4d: 69.184.1.0/26 via 0.0.0.0 in 4 hops
26w4d: 69.184.4.0/26 via 0.0.0.0 in 5 hops
26w4d: 69.184.5.0/26 via 0.0.0.0 in 4 hops
26w4d: RIP: received v2 update from 10.50.0.14 on Vlan50
26w4d: 69.184.0.0/26 via 0.0.0.0 in 4 hops
26w4d: 69.184.1.0/26 via 0.0.0.0 in 5 hops
26w4d: 69.184.4.0/26 via 0.0.0.0 in 4 hops
26w4d: 69.184.5.0/26 via 0.0.0.0 in 5 hops
26w4d: RIP: sending v2 update to 224.0.0.9 via Vlan110 (10.10.10.2)
26w4d: RIP: build update entries
26w4d: 10.31.0.0/16 via 0.0.0.0, metric 1, tag 0
26w4d: 10.32.0.0/16 via 0.0.0.0, metric 1, tag 0
Anthony
Thannk you for the additional information. It does confirm that the problem is not overlapping addresses with RIP advertisements from the other routers. But it does not point clearly to what the problem is. Can you verify that the prefixes advertised on vlan110 (172.20.1.0, 208.224.251.0, and 209.208.175.0) are not learned from some other source (other protocol)? Could you post the router config and perhaps the output of show ip interface brief?
Rick
209
