01-14-2012 08:27 AM - edited 03-04-2019 02:54 PM
Hi everybody
How is everybody doing ?
Please consider the following routing table:
R2#show ipv6 route
IPv6 Routing Table - 7 entries
Codes: C - Connected, L - Local, S - Static, R - RIP, B - BGP
U - Per-user Static route, M - MIPv6
I1 - ISIS L1, I2 - ISIS L2, IA - ISIS interarea, IS - ISIS summary
O - OSPF intra, OI - OSPF inter, OE1 - OSPF ext 1, OE2 - OSPF ext 2
ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2
D - EIGRP, EX - EIGRP external
C 2000::/64 [0/0]
via ::, Serial0/0
L 2000::1:2/128 [0/0]
via ::, Serial0/0
R 2000:1::/64 [120/2]
via FE80::C200:FFF:FE78:0, Serial0/0
C 2001::/64 [0/0]
via ::, Serial0/0
L 2001::2/128 [0/0]
via ::, Serial0/0
R 4000::/64 [120/2]
L FF00::/8 [0/0]
via ::, Null0
R2#show ipv6 rip next-hops
RIP process "zee", Next Hops
FE80::C200:FFF:FE78:0/Serial0/0 [4 paths]
My question is why the above output shows" 4 paths" ? I can only see two routes that were learned via next hop FE80:c200:FF"FE78:0
Thanks and have a great weekend
Solved! Go to Solution.
01-14-2012 08:46 AM
According to the command reference at:
http://www.cisco.com/en/US/docs/ios/ipv6/command/reference/ipv6_16.html#wp2669594
this would be: The number of routes in the IPv6 RIP routing table using the specified next hop
That would match exactly with your output, the only difference being that the keyword 'paths' is used instead.
Probably that is a matter of which IOS version you are using.
regards,
Leo
BTW: There is also an ipv6 related forum. Perhaps you can consider posting additional ipv6 questions there.
01-14-2012 08:46 AM
Hi Sarah,
Can you please post the show ipv6 rip database output as well?
Best regards,
Peter
01-15-2012 01:26 AM
Hi Sarah,
Apparently," show ipv6 rip next-hops" command gets its output from rib database not from routing table.
That's my understanding as well.
Next thing I noticed R1 advertised prefix 1111::/64 with metric 2 to R2.
But should the metric not be 1 as R1 and R2 are connected via serial interface ?
In RIPng, the metric is increased when receiving an update. This is in stern difference to previous RIP versions in which the metric was incremented when sending, and receiving routers simply accepted the metric without further incrementing it. Directly connected prefixes are advertised with initial hop count of 1 in Cisco's RIPng implementation, and after the receiving router increments the hop count by one, it yields the metric value of 2 you are seeing in your routing table.
Best regards,
Peter
01-14-2012 08:46 AM
regards,
Leo
01-14-2012 08:46 AM
Hi Sarah,
Best regards,
Peter
01-14-2012 12:23 PM
Hi Peter
how are you doing?
I apologize for being late; I was recreating the set-up.
R1 s0/0---2001::/64--------s0/0R2
R1's
int loopback1
1111::1/64
ipv6 rip sarah enable
Below is the outputs of various commands on R2.
R2#show ipv6 route
IPv6 Routing Table - 4 entries
R 1111::/64 [120/2]
via FE80::C200:5FF:FE74:0, Serial0/0
C 2001::/64 [0/0]
via ::, Serial0/0
L 2001::2/128 [0/0]
via ::, Serial0/0
L FF00::/8 [0/0]
via ::, Null0
FE80::C200:5FF:FE74:0/Serial0/0 [2 paths]
R2#show ipv6 rip database
RIP process "zee", local RIB
1111::/64, metric 2, installed
Serial0/0/FE80::C200:5FF:FE74:0, expires in 159 secs
2001::/64, metric 2
I also noticed even though R1 and R2 are connected via serial interface which is configured with 2001::/64,R1 still advertises the prefix 2001::/64 to R2.
Had R1 and R2 been configured for ipv4, R1 would not have advertised 2001:: /64 to R2.
01-15-2012 01:26 AM
Hi Sarah,
Best regards,
Peter
