RIPV2 - Newbie
Gange
Hi!
So I am trying to set up the attached topology and I have to say that I have no clue what I am doing wrong.
The problem I have is that I've been trying to ping from R1 to R3 with no success. I've kind of understood that the problem lies in R2 because I can't ping from R1 to the "internet" or the Lo0 either. But exactly what the problem is, I don't know.
I discovered the problem when I checked to see if R1 and R3 had learned the "Gateway of last resort" after the "default-information originate" command which they had not.
How do I upload packet tracer files here? I thought it would be much easier to get help if you could download my file but it wouldn't let me upload ".pkt" files...
If someone could help me and tell me what I'm doing wrong I would be so happy, (test on wednesday..)
I will just post the running config until I can upload the pkt file.
#R1
Building configuration...
Current configuration : 1395 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R1
enable secret 5 $1$mERr$9cTjUIEqNGurQiFU.ZeCi1
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524XZCO
spanning-tree mode pvst
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.21
encapsulation dot1Q 21
ip address 192.168.21.1 255.255.255.0
interface GigabitEthernet0/1.23
encapsulation dot1Q 23
ip address 192.168.23.1 255.255.255.0
interface GigabitEthernet0/1.99
encapsulation dot1Q 99
ip address 192.168.99.1 255.255.255.0
interface Serial0/1/0
ip address 172.16.1.1 255.255.255.252
clock rate 128000
interface Serial0/1/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router rip
version 2
passive-interface GigabitEthernet0/1
passive-interface Serial0/1/0
network 172.16.0.0
network 192.168.21.0
network 192.168.23.0
network 192.168.99.0
no auto-summary
ip classless
ip flow-export version 9
line con 0
password cisco
logging synchronous
login
line aux 0
line vty 0 4
password cisco
logging synchronous
login
end
#R2
Current configuration : 1205 bytes
version 15.1
hostname R2
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX15245624
interface Loopback0
ip address 10.10.10.10 255.255.255.255
ip address 209.165.200.233 255.255.255.248
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip address 172.16.1.2 255.255.255.252
ip address 172.16.2.1 255.255.255.252
clock rate 128000
interface Vlan1
no ip address
shutdown
router rip
version 2
passive-interface Serial0/1/1
passive-interface Loopback0
network 10.0.0.0
network 172.16.0.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 209.165.200.238
line con 0
password cisco
logging synchronous
login
line aux 0
line vty 0 4
password cisco
logging synchronous
login
end
#R3
Current configuration : 1290 bytes
version 15.1
hostname R3
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524XVNI
interface Loopback4
ip address 192.168.4.1 255.255.255.0
interface Loopback5
ip address 192.168.5.1 255.255.255.0
interface Loopback6
ip address 192.168.6.1 255.255.255.0
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
clock rate 2000000
shutdown
ip address 172.16.2.2 255.255.255.252
interface Vlan1
no ip address
shutdown
router rip
version 2
passive-interface Loopback4
passive-interface Loopback5
passive-interface Loopback6
network 172.16.0.0
network 192.168.4.0
network 192.168.5.0
network 192.168.6.0
no auto-summary
ip classless
line con 0
password cisco
logging synchronous
login
line aux 0
line vty 0 4
password cisco
logging synchronous
login
end
If you configure passive-interface, these interface will not receive routing information.
Passive-interface is recommended for the interface associated to the LAN's only, you could use it for loopbacks as well but it is optional.
The RIP configuration should be:
R1
router rip
version 2
network 172.16.0.0
no auto-summary
R2
router rip
version 2
network 10.0.0.0
network 172.16.0.0
no auto-summary
R3
router rip
version 2
network 172.16.0.0
network 192.168.4.0
network 192.168.5.0
network 192.168.6.0
no auto-summary
For NAT on R2, it should be:
ip nat outside
duplex auto
speed auto
ip nat inside
ip nat inside
clock rate 128000
ip access-list standard MY-LAN
(Include your LAN here)
permit 192.168.4.0 0.255.255.255
permit 192.168.5.0 0.255.255.255
permit 192.168.6.0 0.255.255.255
permit 192.168.21.0 0.255.255.255
permit 192.168.23.0 0.255.255.255
permit 192.168.99.0 0.255.255.255
ip nat inside source list MY-LAN interface g0/0 overload
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
7 Replies 7
R1
router rip
version 2
network 172.16.0.0
no auto-summary
R2
router rip
version 2
network 10.0.0.0
network 172.16.0.0
no auto-summary
R3
router rip
version 2
network 172.16.0.0
network 192.168.4.0
network 192.168.5.0
network 192.168.6.0
no auto-summary
ip nat outside
duplex auto
speed auto
ip nat inside
ip nat inside
clock rate 128000
Hope it is useful
It was very helpful! Misread the instructions to only make some of the interfaces passive but now it works thanks!
You are welcome, have a good day!
nbhayman1
just a quick question, I'm a newb also and I was wondering why R1 has the default-information originate configured. Does RIP 2 place it there? cuz I don't see it in R3.
Just curious
The default-information originate command is used to advertise a default route to other routers running the same protocol dynamically otherwise we should create default static routes on each router pointing to the exit or edge router.
As it can be seen on the shared configuration, R2 is the one advertising a default route via RIP, take in consideration R2 must have a default static route pointing to Internet otherwise the unknow requests will be discarded.
Got it, thanks. I was just wondering why the command was on the router connected to the lan. I was under the impression that it was only needed on the router with the default route to the internet
That is correct
