10-17-2014 12:43 PM - edited 03-04-2019 11:59 PM
Hi i want to connect a Macbook pro using a rj45 to rj45 console cable to set up a switch but i don't know what to do and no information about it online only about usb. Can anyone help? Thanks
10-17-2014 01:14 PM
If you have a MacBook Pro, you don't have a serial port. And you can't connect an Ethernet-Port to the serial-port of the switch. You need:
10-17-2014 02:10 PM
HI i have this cable and its a console cable i just don't know how to set it up in terminal. http://www.amazon.co.uk/StarTech-Cisco-Console-Rollover-Cable/dp/B004Z9YG5W/ref=sr_1_2?ie=UTF8&qid=1413580192&sr=8-2&keywords=rj45+to+rj45+console+cable . Thanks
10-17-2014 02:42 PM
That's just a console-cable. You have to connect it to a serial port on your computer. For a MacBookPro you need something like that this: http://www.amazon.co.uk/Plugable-Adapter-Prolific-PL2303HX-Chipset/dp/B00425S1H8/ref=pd_sim_computers_2?ie=UTF8&refRID=1SFDM07E5GZ3G5V86983
10-18-2014 01:05 AM
Hi that works in a pc without serial port too? thanks
10-18-2014 01:14 AM
Yes, just make sure that the Chip that is used in the adapter is supported for the OS you are using.
10-18-2014 09:46 AM
ok thanks
