Road runner and 1760 router
I would like to know if there is anyway to connect my 1760 router into my home connection. My ISP is roadrunner. I do not understand if you can have a router port obtain an Ip addres through DHCP. Any help would be apprecaited. Thanks
1 REPLY
Re: Road runner and 1760 router
Yes you can have your router interface obtaining its IP via DHCP using "ip address negotiated" command under this interface.
HTH, please do rate all helpful posts,
Mohammed Mahmoud.
131
