Webcast-Catalyst9k
Rotue Map
What is the difference between the command set ip next-hop & set ip default next-hop in policay routing..
Hall of Fame Super Silver
Re: Rotue Map
Hello Bava,
set ip next-hop diverts traffic regardless of current IP routing table.
set ip default next-hop first looks at the IP routing table if an entry exists for packet destination normal destination routing takes place, if no specific route for packet destination exists the packet is sent to the specified next-hop.
Hope to help
Giuseppe
Re: Rotue Map
Thanks Qiuslar,
Now if i have a default route in my routing table will the packet reach destination via default route or else is there any specific route needed for the destination in order to avoid looking Route map ip default next-hop..
thanks in advance
Re: Rotue Map
Hello Bava,
see
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_pi2.html#wp1012080
specific route is not a default route, if a specific route for the destination is missing set ip default next-hop sends the packet to the next-hop.
the default route is not considered a specific route.
Hope to help
Giuseppe
160
