Route exchange between VRF locally?
koksm
Since i am a complete nono in this area...
Is it possible to exchange routes between two VRF's on a local router?
This is what i tested and it works
ip vrf Server
rd 3:3
route-target export 3:3
route-target import 1:1
route-target import 2:2
ip vrf Cust1
rd 1:1
route-target export 1:1
route-target import 3:3
ip vrf Cust2
rd 2:2
route-target export 2:2
router bgp 65000
no synchronization
bgp log-neighbor-changes
no auto-summary
address-family ipv4 vrf Cust2
redistribute connected
no synchronization
exit-address-family
address-family ipv4 vrf Cust1
no synchronization
exit-address-family
address-family ipv4 vrf Server
no synchronization
exit-address-family
This import sinto vrf Server the connected routes from vrf Cust1 and Cust2.
Narayan
6 Replies 6
royalblues
Level 10
Level 10
Yes it can be done. Just import the required route-targets on the VRF
eg.
ip vrf cut2
rd 3:3
route-target import 1:1----imports VRF cust1 routes
ip vrf Cust1
rd 1:1
Narayan
We have tried this, but the routes did not show up in the routing table. Should they?
Thnx!
yes... are you trying on VRF lite by any chance?
The point is you need BGP irrespective of whether you have any bgp peering neighbors to import routes
Narayan
Yes, VFR lite, you are correct.
We have BGP running. It was already in there between this router and two other ones.
Anything special to be done in BGP
ip vrf Server
rd 3:3
ip vrf Cust1
rd 1:1
ip vrf Cust2
rd 2:2
router bgp 65000
no synchronization
no auto-summary
no synchronization
exit-address-family
no synchronization
exit-address-family
no synchronization
exit-address-family
Narayan
Right, that did the trick.
I found a document on CCO which basically explains the same. But it didn't ring a bell about the redistribute...
Thanx again!
