Webcast-Catalyst9k
Route map on Tun Gre interface
I'm trying to set o route map on a GRE tunnel interface.
The router has two eth interfaces.
Trafic is comming on eth1 gre encapsulated and has to go out on the same interface unencapsulated only if it's coming and going to specific ip addresses.
The config is as follows:
ip access-list extended R1
permit ip host xx.xx.xx.xx host yy.yy.yy.yy
route-map R1 permit 10
match ip address R1
set ip default next-hop uu.uu.uu.uu
interface Tunnelzz
ip address aa.aa.aa.aa
tunnel source bb.bb.bb.bb
tunnel destination cc.cc.cc.cc
When I do a <<sh route-map>> the router display 0 matches.
Any help would be very appreciated.
Best regards,
Adrian
Purple
Re: Route map on Tun Gre interface
Adrian,
You need to apply it to the tunnel interface as follows:
interface Tunnelzz
ip policy route-map R1
Paresh
PS. Pls do rate posts.
Paresh,
It is applied as you said and the result did not changed.
Looks like on the Gre tunnel interface the incomming traffic is not matched by ACL.
I tryed on the GRE int the followin:
access-list 10 permit host 10.31.2.250
access-list 10 permit any
interface Tunnelzz
ip access-group 10 in
I am sure that I have trafic comming from 10.31.2.250 on the Tunnelzz but when i do:
sh access-lists
I have 0 matches on first rule and a lot of matches on the second one.
Adrian
How about you apply the route-map on the eth1 interface rather than the GRE interface?
Maybe I misunderstood your question.
206
