route-map problem
I have 2 routers with the folowing config:
hostname R5
interface Ethernet0
ip address 10.10.10.1 255.255.255.0
router bgp 500
bgp log-neighbor-changes
neighbor 10.10.10.2 remote-as 700
neighbor 10.10.10.2 route-map block7 in
neighbor 20.20.20.1 remote-as 100
ip as-path access-list 1 deny _700$
route-map block7 permit 10
match as-path 1
route-map block7 permit 20
another router is R7:
interface Loopback0
ip address 7.7.7.7 255.255.255.255
interface Loopback1
ip address 6.6.6.6 255.255.255.255
interface Loopback2
ip address 8.8.8.8 255.255.255.255
interface Ethernet0/0
ip address 10.10.10.2 255.255.255.0
router bgp 700
network 6.6.6.6 mask 255.255.255.255
network 7.7.7.7 mask 255.255.255.255
network 8.8.8.8 mask 255.255.255.255
neighbor 10.10.10.1 remote-as 500
neighbor 10.10.10.1 route-map addas out
access-list 1 permit 7.7.7.7
access-list 2 permit 6.6.6.6
route-map addas permit 10
match ip address 1
set as-path prepend 777
route-map addas permit 20
match ip address 2
set as-path prepend 666
route-map addas permit 30
___
From R5, I want to see some network were blocked because of the route-map, but I saw allof them:
R5#sh ip bgp
BGP table version is 10, local router ID is 137.20.33.33
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 6.6.6.6/32 10.10.10.2 0 0 700 666 i
*> 7.7.7.7/32 10.10.10.2 0 0 700 777 i
*> 8.8.8.8/32 10.10.10.2 0 0 700 i
R5#
After I remove the "route-map block7 permit 20" from R5, I got this:
R5#sh ip bgp
R5#
My understanding is: 6.6.6.6/32, 7.7.7.7/32 and 8.8.8.8/32 should be blocked because of the route-map 10 on the R5 before it passing through route-map block7 permit 20. That is there should be no difference before and after I remove the command. but from the result, I am wrong, can some one explain this?
1 ACCEPTED SOLUTION
Purple
Re: route-map problem
Always happy to be of assistance, mate !
Ok, here's the difference. When you use a deny within the as-path access-list, it denies the specified route for the purpose of matching within a subsequent entry in a route-map. Which means that the match condition within the route-map will not match so it will evaluate the next clause in the route-map. That is why it falls through to 'route-map block7 permit 20' in your case. Also, since there is an implicit deny within the as-path acl, having a single deny statement does not make sense.
Now, looking at my way of doing it: the as-path will match routes with the specified AS-PATHs. When used as a match statement within a route-map, the use of that as-path ACL will cause a match for routes with that AS-PATH. The route-map will then look at the action associated with that clause - permit or deny. Since it is a deny, these routes will not be let through.
Hope that helps - pls do rate the post if it does.
Paresh
Purple
If I understand what you are trying to do, you are trying to block routes with an AS-PATH that ends with 700. Is that correct ? If so, you want to block 8.8.8.8/32 but let the others through ?
If so, here is what you need on R5:
router bgp 500
ip as-path access-list 1 permit _700$
route-map block7 deny 10
match as-path 1
The trick is that you should permit the routes you want matched with your as-path access-list. Then deny those routes using the route-map.
Paresh
hi Paresh, thanks for your quick reply, you solved my lots pf problem...
The pronblem is I know how to config, but I just cannot understand my current configration.
Now Can you answer my another question:
what is the difference between:
match as-path 1
and:
ip as-path access-list 1 DENY _700$
route-map block7 PERMIT 10
match as-path 1
you put the deny in the route-map while I put the deny in the as-path access list.
Purple
Paresh
120
