Route-map "next hop" questions
Needing to set some "next-hop" statements with a route map. These will be applied to Vlan24 interface (10.122.24.1/23).
I want to split outbound (0.0.0.0) Internet access for Vlan24 across two endpoints based on the workstaton subnet. No issues doing that.
But my question is do I have to specify a "next-hop" if I want the traffic specifed in "route-map internet permit 11" to use Vlan24 for its "next hop"?
Will not having any statement allow match traffic to continue to use Vlan24 interface as before? Or must I have a "set ip next-hop 10.122.24.1" so traffic will continue to use 24.1 for "next hop".
interface Vlan24
ip address 10.122.24.1 255.255.254.0
ip policy route-map internet
match ip address 11
route-map internet permit 12
match ip address 12
set ip next-hop 10.122.100.20
What I would really like to do is just direct all unknown traffic to 10.122.100.20 and to allow specified hosts to continue to use 10.122.24.1 as their default gateway and let the swtich route them as normal. But I don't think this is possible.
Switch is 6513 hybrid-mode running 12.2(17d)SXB11 on the Sup32.
thanks
Re: Route-map "next hop" questions
Doug,
You could simply remove instance number 11 and traffic not matching instance 12 would be routed according to the default gateway installed in the RIB.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
hi HAROLD
this is 5 from :)
To do what I want should have "set default ip next-hop, not "set ip next-hop".
This will only send unknown traffic to the "next-hop" if there are not explicit routes for it in the router.
The "set ip next-hop" will send all traffic to the next hop, not unknow traffic. A great way to overload a router with unnecessary traffic. :)
254
