02-10-2009 03:38 AM - edited 03-04-2019 03:30 AM
I have configured route-map on my two routers connected with a serial cable, my problem is when I do show route-map I dont see matches.
below are my routers configs:
Router A
access-list 110 permit ip host 192.1.1.2 any
route-map policy_1 permit 10
match ip address 110
set interface GigabitEthernet0/1 Serial0/0/0
interface Serial0/0/0
bandwidth 8000
ip address 165.148.120.1 255.255.255.252
ip policy route-map policy_1
ip ospf network broadcast
no keepalive
clock rate 8000000
Router B
access-list 110 permit ip host 192.2.1.2 any
set interface Serial0/0/0
ip address 165.148.120.2 255.255.255.252
no keepalive
sh route map results below for both routers
route-map policy_1, permit, sequence 10
Match clauses:
ip address (access-lists): 110
Set clauses:
Policy routing matches: 0 packets, 0 bytes
Can anyone help please?
02-10-2009 03:45 AM
U have specified to set the interface to be gig0/1 and s0/0/0 can u verify weather u r able to reach the mentioned ip through that interface.
Mahmood
02-10-2009 03:58 AM
Thanks you the man, that was my mistake to set the g0/1 and s0/0/0. I dont know why I did not spot that. I spent 3 hours trying to figure that one out but I could not.
